[foam-extend.org] OF-extend 4.0: compiling with CUDA
Old   March 15, 2018, 08:08
Default OF-extend 4.0: compiling with CUDA
James Gross
jgross is on a distinguished road
I am trying to link my already installed version of OF-extend 4.0 with the CUDA solvers. I have followed the installation guide of CUDA correctly, and it is working just fine for the examples (i.e. deviceQuery, etc) provided in the build. Therefore, it must have something to do with the way OF-extend and CUDA are linked.
I have followed the advice from a forum post of a similar, but slightly different issue:
HTML Code:
https://www.cfd-online.com/Forums/openfoam-installation/128834-extend-3-0-cuda-installation.html
However, any time I try to run the Allwmake in $FOAM_SRC/cudaSolvers directory, I consistently receive the following:
No nvcc - CUDA not available.
The Allwmake script is as follows:
#!/bin/bash
cd ${0%/*} || exit 1    # run from this directory
if [ -f $CUDA_BIN_DIR/nvcc ]
then
    if [ -z $CUDA_IGNORE ]
    then
        echo "Found nvcc  --  enabling CUDA support."
        wmake libso
    else
        echo "Found nvcc but \$CUDA_IGNORE set -- not  enabling CUDA support."
    fi
else
    echo "No nvcc - CUDA not available."
fi
This means that the Allwmake is not finding the nvcc file in $CUDA_BIN_DIR. I have exported it correctly in both the prefs.sh and settings.sh located in the .../foam-extend-4.0/etc directory.
export CUDA_DIR=/usr/local/cuda-9.1
export CUDA_BIN_DIR=$CUDA_DIR/bin
Furthermore, when I run
which nvcc
I get the following output:
/usr/local/cuda-9.1/bin/nvcc
I thought I could try to export the directories directly in the Allwmake script because they are clearly not using the prefs.sh or settings.sh to find the file. However, when I try this, I get the following output:
cudaSolver/cudaTypes.H:57:29: fatal error: cusp/coo_matrix.h: No such file or directory
compilation terminated.
In file included from cudaCG/cudaCG.C:26:0:
cudaCG/cudaCG.H:43:24: fatal error: cudaSolver.H: No such file or directory
cudaSolver/cudaSolver.dep:268: recipe for target 'Make/linux64GccDPOpt/cudaSolver.o' failed
make: *** [Make/linux64GccDPOpt/cudaSolver.o] Error 1
make: *** Waiting for unfinished jobs....
cudaCG/cudaCG.dep:269: recipe for target 'Make/linux64GccDPOpt/cudaCG.o' failed
make: *** [Make/linux64GccDPOpt/cudaCG.o] Error 1
In file included from cudaBiCGStab/cudaBiCGStab.C:34:0:
cudaBiCGStab/cudaBiCGStab.H:43:24: fatal error: cudaSolver.H: No such file or directory
cudaBiCGStab/cudaBiCGStab.dep:269: recipe for target 'Make/linux64GccDPOpt/cudaBiCGStab.o' failed
make: *** [Make/linux64GccDPOpt/cudaBiCGStab.o] Error 1
cudaCG/cgAmg.cu:47:23: fatal error: cudaTypes.H: No such file or directory
cudaCG/cgAmg.dep:8: recipe for target 'Make/linux64GccDPOpt/cgAmg.o' failed
make: *** [Make/linux64GccDPOpt/cgAmg.o] Error 1
cudaCG/cgDiag.cu:47:23: fatal error: cudaTypes.H: No such file or directory
cudaBiCGStab/bicgDiag.cu:47:23: fatal error: cudaTypes.H: No such file or directory
cudaCG/cgAinv.cu:47:23: fatal error: cudaTypes.H: No such file or directory
cudaCG/cgDiag.dep:8: recipe for target 'Make/linux64GccDPOpt/cgDiag.o' failed
make: *** [Make/linux64GccDPOpt/cgDiag.o] Error 1
cudaBiCGStab/bicgAinv.cu:47:23: fatal error: cudaTypes.H: No such file or directory
cudaBiCGStab/bicgDiag.dep:7: recipe for target 'Make/linux64GccDPOpt/bicgDiag.o' failed
make: *** [Make/linux64GccDPOpt/bicgDiag.o] Error 1
cudaCG/cgAinv.dep:8: recipe for target 'Make/linux64GccDPOpt/cgAinv.o' failed
make: *** [Make/linux64GccDPOpt/cgAinv.o] Error 1
cudaBiCGStab/bicgAinv.dep:7: recipe for target 'Make/linux64GccDPOpt/bicgAinv.o' failed
make: *** [Make/linux64GccDPOpt/bicgAinv.o] Error 1
So it is not recognising all of the files located in the directory $FOAM_SRC/cudaSolvers, even though they are all there.
Does anyone have any suggestions as to how to get the Allwmake to run correctly?
Thank you in advance.
J
jgross is offline   Reply With Quote
Old   March 18, 2018, 15:44
Retired Super Moderator
Bruno Santos
Greetings jgross,
Run the following command:
ls -l $FOAM_SRC/cudaSolvers/lnInclude
If it does not give you a list of files symbolically linked to other files, including the file "cudaTypes.H", then that's the reason why it's not working.
Either way, try running the following commands, to try and see if it solves the issue:
cd $FOAM_SRC/cudaSolvers
wclean libso
wmake libso
Beyond this, I have no idea with which CUDA versions foam-extend 4.0 has been tested with. It's possible that it may only work with CUDA 8.x or 7.x.
Best regards,
Bruno
Old   March 19, 2018, 07:44
James Gross
Hi Bruno,
Thank you for your response. Your assistance is greatly appreciated.
I checked the contents of the lnInlcude directory, and received all the necessary symbolic links:
total 0
lrwxrwxrwx 1 jg847 jg847 28 Mar 18 19:34 buildNormFactor.H -> ../include/buildNormFactor.H
lrwxrwxrwx 1 jg847 jg847 30 Mar 18 19:34 cudaBiCGStab.C -> ../cudaBiCGStab/cudaBiCGStab.C
lrwxrwxrwx 1 jg847 jg847 30 Mar 18 19:34 cudaBiCGStab.H -> ../cudaBiCGStab/cudaBiCGStab.H
lrwxrwxrwx 1 jg847 jg847 18 Mar 18 19:34 cudaCG.C -> ../cudaCG/cudaCG.C
lrwxrwxrwx 1 jg847 jg847 18 Mar 18 19:34 cudaCG.H -> ../cudaCG/cudaCG.H
lrwxrwxrwx 1 jg847 jg847 26 Mar 18 19:34 cudaSolver.C -> ../cudaSolver/cudaSolver.C
lrwxrwxrwx 1 jg847 jg847 26 Mar 18 19:34 cudaSolver.H -> ../cudaSolver/cudaSolver.H
lrwxrwxrwx 1 jg847 jg847 25 Mar 18 19:34 cudaTypes.H -> ../cudaSolver/cudaTypes.H
lrwxrwxrwx 1 jg847 jg847 26 Mar 18 19:34 fillCOOMatrix.H -> ../include/fillCOOMatrix.H
-rw-rw-r-- 1 jg847 jg847  0 Mar 18 19:34 uptodate
Also, I tried your suggestion, but I am still receiving the same error message:
In file included from cudaSolver/cudaSolver.H:42:0,
                 from cudaSolver/cudaSolver.C:26:
I will try to install CUDA 8.x later to see if that fixes the problem.
James
Old   March 19, 2018, 10:51
James Gross
Hi Bruno,
It turns out I didn't link the Cusp library correctly as it needed to be in the directory:
$WM_THIRD_PARTY_DIR/LocalDev
I am able to run
wmake libso
without the same errors. I'm not 100% sure it installed correctly, but at least it's a different from before. I would like to test the cudaSolvers, however I cannot link
"libcudaSolvers.so"
in the controlDict as it the .so file does not exist.
My guess is that although it is recognising those files now, it still encountered some fatal errors during installation, even though I didn't find any fatal error messages in the log file.
Any advice on how to proceed further with this?
James
Old   November 5, 2020, 01:39
Default Hi Jgross,have you solved this problem?
Thomas Shi
ThomasLong is on a distinguished road
I am facing the same problem now. I have just finished the installation of CUDA-11.1 on Ubuntu 18.04 of WSL2 and it works well for the examples. Then the compilation of Foam-extend 4.0 has no problems. But when I run ./Allwmake in $FOAM_SRC/cudaSolvers directory , I recieve the same message "No nvcc - CUDA not available." as you. I want to know if you have any sollution to this problem.
ThomasLong is offline   Reply With Quote
Old   December 8, 2022, 09:35
tav
Tom
tav is on a distinguished road
Originally Posted by jgross View Post
Hi Bruno,
I am able to run
wmake libso
"libcudaSolvers.so"
James
Hi James,
I am getting the same error while compiling foam-extend 5.0. Can you please share how you linked the Cusp library correctly?
tav is offline   Reply With Quote
Problem using turbulent modelling with rhoCentralFoam in foam extend 4.0 quarkz OpenFOAM Running, Solving & CFD 1 May 8, 2023 14:27
probe Locations error in the dynamicMesh foam extend 4.0 vahidreza lotfi OpenFOAM Post-Processing 2 August 22, 2018 11:30
MRFSimpleFoam for a centrifugal pump (OF Extend 4.0): slow and no convergence jgross OpenFOAM Running, Solving & CFD 6 February 17, 2018 10:37
[foam-extend.org] Foam Extend 4.0 on MAC simone.rowing OpenFOAM Installation 1 July 2, 2017 16:23
Paraview 4.1.0 cmake compiling error CUDA Convolution Driver Juan Carlos OpenFOAM Installation 3 April 17, 2014 14:37
