[OpenFOAM.com] OpenFOAM install on high performance computing machine running x86_64 linux |
March 8, 2018, 15:19 |
Gaurav
I've been trying to install openFOAM-v1712 on a supercomputer running linux (architecture x86_64). I can get through the third party compiles without any problems, but when it gets to the openfoam compile I get "mpicc not found". I also get that message when I initially do " source ~/OpenFOAM/OpenFOAM-v1712/etc/bashrc " The default cc on the system is the cc that comes with cray, or intel (if I switch modules). Is there a workaround to mpicc? Thanks Gaurav |
March 8, 2018, 16:52 |
#2 | |
Hosein
Rep Power: 15 |
you need to have openmpi installed in order to be able to use mpicc. And if you already have it installed you need to export the path as it is said in this forum https://stackoverflow.com/questions/...mmand-in-linux Or if you want to completely change the compiling, there is a file in foam in which the details of compilers are written and you may change it from there (sorry but I don't remember the name of it now ). Hope this helps... Last edited by wyldckat; March 17, 2018 at 18:10. Reason: turned the last link into an actual link |
Running icepak on a linux machine | Codemaster | FLUENT | 0 | November 20, 2008 01:50 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
OpenFOAM installation problem on Linux 32bit | kumar | OpenFOAM Installation | 0 | April 27, 2007 06:41 |
Running Fluent on Linux AMD machine | David Reinbold | FLUENT | 5 | September 21, 2001 18:08 |
PC vs. Workstation | Tim Franke | Main CFD Forum | 5 | September 29, 1999 16:01 |
