[foam-extend.org] Install foam-extend 1.6 from source, scotchDecomp error. |
September 28, 2017, 12:17 |
Katt
Rep Power: 9 |
Hi guys;
I am using RedHat Linux with no internet/ no administrative privileges (theres no other way, I have to deal with this "fortunately/ unfortunately"). I have installed several versions of OpenFOAM/ Foam-Extend on my laptop as a sudo user and never came across any problem. Coming to my case, for many days, I have been trying to build Foam-Extend-1.6 from the source code and install ThirdParty libraries manually. That is, download required libraries and run the ThirdParty script individually. Initially I came across MPI problem which I solved and presently struggling with scotchDecomposition problem. After running the ThirdParty stages individually, I run the FE-1.6 installation but come across the following erros: + wmake libso scotchDecomp SOURCE=scotchDecomp/scotchDecomp.C ; --------------------------- SOURCE=engineScotchDecomp/engineScotchDecomp.C ; -------------- scotchDecomp/scotchDecomp.H: 39:33: error: decompositionMethod.H: No such file or directory and the errors continue in the lnInclude/scotchDecomp.H. I hope I am not the 1st one struggling with these weird administrative problems and would appreciate if anyone can help me out. |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 19:13 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 07:25 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
