[OpenFOAM.org] Open FOAM 4.1 installation on Ubuntu 17.04 (32 bit). |
Rep Power: 9 ![]() |
Hi All,
I have tried to install Open FOAM 4.1 on Ubuntu 17.04. I have compiled paraview successfully, but when I try to compile the open FOAM folder using the command : ./Allwmake -j 2 > log.make 2>&1 the problem starts. The process continues for some time and there were some solvers compiled successfully. The process is not complete and the meshing application like blockMesh is not made! The end few lines of the log file is given below: Code:
Making dependency list for source file refinementLevel.C g++ -std=c++0x -m32 -Dlinux -DWM_ARCH_OPTION=32 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c refinementLevel.C -o /home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/mesh/advanced/refinementLevel/refinementLevel.o g++ -std=c++0x -m32 -Dlinux -DWM_ARCH_OPTION=32 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed /home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/mesh/advanced/refinementLevel/refinementLevel.o -L/home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/lib \ -lfiniteVolume -lmeshTools -lOpenFOAM -ldl \ -lm -o /home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/bin/refinementLevel /home/gokul/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/advanced/removeFaces Making dependency list for source file removeFaces.C g++ -std=c++0x -m32 -Dlinux -DWM_ARCH_OPTION=32 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/dynamicMesh/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c removeFaces.C -o /home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/mesh/advanced/removeFaces/removeFaces.o g++ -std=c++0x -m32 -Dlinux -DWM_ARCH_OPTION=32 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/dynamicMesh/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/home/gokul/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed /home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/mesh/advanced/removeFaces/removeFaces.o -L/home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/lib \ -lmeshTools -ldynamicMesh -lfiniteVolume -lgenericPatchFields -lOpenFOAM -ldl \ -lm -o /home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/bin/removeFaces /home/gokul/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/advanced/selectCells make[3]: *** Deleting file '/home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/mesh/advanced/selectCells/sourceFiles' /home/gokul/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8: recipe for target '/home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/parallelProcessing/decomposePar/decomposePar.o' failed make[2]: *** [/home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/parallelProcessing/decomposePar/decomposePar.o] Hangup /home/gokul/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: recipe for target 'selectCells' failed make[2]: *** [selectCells] Hangup /home/gokul/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: recipe for target 'advanced' failed make[1]: *** [advanced] Hangup /home/gokul/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: recipe for target 'mesh' failed make: *** [mesh] Hangup /home/gokul/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: recipe for target 'parallelProcessing' failed make: *** [parallelProcessing] Hangup /home/gokul/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: recipe for target 'decomposePar' failed make[1]: *** [decomposePar] Hangup /home/gokul/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/files:60: recipe for target '/home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/mesh/advanced/selectCells/sourceFiles' failed make[3]: *** [/home/gokul/OpenFOAM/OpenFOAM-4.1/platforms/linuxGccDPInt32Opt/applications/utilities/mesh/advanced/selectCells/sourceFiles] Hangup Last edited by wyldckat; September 6, 2017 at 18:08. Reason: Added [CODE][/CODE] markers |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: I'm guessing that you are following the instructions from here: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04
In order for the error message "Hangup" to appear, I'm guessing that the problem is that there isn't enough RAM in the machine or associated to the virtual machine. If you are using Ubuntu 17.04 inside a virtual machine, then my guess is that you kept the default 1GB of RAM associated to it. That would explain why using 2 cores will not work as intended. Restart (reboot) the machine that has Ubuntu installed in it. Then try using the following commands, after starting a new terminal window within Ubuntu: Code:
of41 foam ./Allwmake > log.make 2>&1
#3 | |
Hi Bruno,
Yes, I was following the above instructions. I am not using any virtual machine. I restarted my PC and tried the above command and I got the following error: Code:
-bash: log.make: Permission denied Code:
sudo apt install openfoam Quote:
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
