[OpenFOAM.org] Problem Installing OpenFOAM V 2.3.1 in Ubuntu 17.04 |
August 30, 2017, 12:51 |
CFD
Rep Power: 16 |
Hi All,
I have installed the latest version of Ubuntu, Version 17.04 and then when I tried to install OpenFoam V 2.3.1 from OpenFoamwiki https://openfoamwiki.net/index.php/I...M-2.3.1/Ubuntu, I got the following error; Code:
make: Target 'application' not remade because of errors. Thank you very much, |
September 2, 2017, 10:10 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I looks like you didn't follow the instructions to the letter. In the log file there are indications that the option "-j" was used with Allwmake, which does not work on OpenFOAM 2.3.1.
Please use the same exact commands as instructed on that wiki page. Beyond that, I have not tested those instructions on Ubuntu 17.04, therefore I don't know if they work well or not.
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[OpenFOAM.com] Problem installing Openfoam from source. Allwmake doesn't work | artymk4 | OpenFOAM Installation | 1 | December 4, 2018 17:03 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS | mukut | OpenFOAM Installation | 9 | January 19, 2015 00:48 |
Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686 | AHutchison | OpenFOAM Installation | 6 | June 4, 2013 12:11 |
