[OpenFOAM.com] v1706: error building paraView 5.4
Old   August 20, 2017, 08:40
Default v1706: error building paraView 5.4
Francisco
Bollonga is on a distinguished road
Hi guys,
I'm trying to install openFOAM-v1706 and paraView-v5.4.0 in Ubuntu 17.04.
I'm installing it from source following all the steps here:
http://www.openfoam.com/download/install-source.php
http://www.openfoam.com/code/build-guide.php
I've modified the bashrc to install everthing in /opt/OpenFOam, sourced it and it was fine.
The problem happens when trying to build paraView:
cd $WM_THIRD_PARTY_DIR
./makeParaView
It gives me the following error:
Error (makeParaView) : not located in $WM_THIRD_PARTY_DIR
    Check your OpenFOAM environment and installation
$WM_THIRD_PARTY _DIR points me to the correct directory, and I can see the file makeParaView inside. Using find makeParaView works as well.
What can be the problem? what can I check next?
Thanks in advance!
Bollonga is offline   Reply With Quote
build, makeparaview, openfoam-1706, paraview 5.4.0
[OpenFOAM.com] Problems compiling ParaView 5.4 suantaraDarma OpenFOAM Installation 4 October 15, 2024 06:42
[General] ParaView 5.4 Crashes with ParticleTracer complexFlow ParaView 1 August 30, 2018 11:13
[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped) dslbkxd OpenFOAM Installation 1 February 3, 2018 01:56
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 14:24
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
