[OpenFOAM.com] v1706 having difficulties getting started and unable to locate folders |
Rep Power: 0 ![]() |
Hello all!!
When I try to open OpenFOAM_Start I get the following message. What should I do? |
Hello NEWBIE WITH LINUX HERE!!!!!
I am having problems with the openfoam file directory. I can not find the applications folder anywhere! My opt folder is empty (I am running ubuntu on vmware). When I run OpenFOAM (./startOpenFOAM) and type the location of solvers folder at bash-4.2$ $FOAM_SOLVERS it returns bash: /opt/OpenFOAM/OpenFOAM-v1706/applications/solvers: Is a directory bash-4.2$ but when I try to find it via files I can't because as I said opt folder is empty! and also when I type the location at a new terminal it says no such file or directory. I am totaly frustrated. Your help will be deaply appreciated!!!! |
The fl process could not be started because of UDF | majid_kamyab | Fluent UDF and Scheme Programming | 6 | December 15, 2015 08:42 |
Parallel Error in ANSYS FLUENT 12 | zeusxx | FLUENT | 25 | July 17, 2015 04:40 |
