[foam-extend.org] How to install mang versions in the same user |
Rep Power: 9 ![]() |
Hi foamers
I have intalled foam-extend-4.0, now I want to continue to install openfoam-4.1 in the same user, what I should do? Thanks. Jack |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: Read the following section at openfoamwiki.net: 2.2 Using aliases to help manage multiple OpenFOAM versions
Thank you very much.
I have successfully installed it. jack |
How to make user routine just be called once in one time step? | doublestrong | CFX | 3 | October 21, 2018 23:06 |
[Other] Using different MPI types and versions with OpenFOAM | spaceprop | OpenFOAM Installation | 2 | May 28, 2018 03:31 |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 08:15 |
How to install two versions of OpenFoam | Argen | OpenFOAM Installation | 25 | August 9, 2012 15:25 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 14:43 |
