[OpenFOAM.org] ./Allwmake: 7: .: Can't open /wmake/scripts/AllwmakeParseArguments
Old   July 3, 2017, 03:10
Default ./Allwmake: 7: .: Can't open /wmake/scripts/AllwmakeParseArguments
Dorian1504 is on a distinguished road
I'm trying to compile Openfoam as explained here :
https://openfoam.org/download/source...ling-openfoam/
But I have the following error when I run Allwmake:
I checked my environment variables but I don't see any mistake.
I'm pretty sure that the problem comes from the variable $WM_PROJECT_DIR, when I replace this in Allwmake by the true path the error disappears but I obtain a new one :
/opt/OpenFOAM/OpenFOAM-4.x$ sudo ./Allwmake
./Allwmake: 9: ./Allwmake: wmakeCheckPwd: not found
Allwmake error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
And when I check with echo :
echo $WM_PROJECT_DIR
Any idea how to solve this problem?
Thank you !
Dorian1504 is offline   Reply With Quote
Old   July 3, 2017, 05:55
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
sudo creates new environment, so in sudo shell WM_PROJECT_DIR is empty. So either use -E flag for sudo, or execute bash under sudo and there source etc/bashrc, compile software, etc.
alexeym is offline   Reply With Quote
Old   July 3, 2017, 07:31
Thank you for your response.
I did not know root created an environment. So, I used the -E flag and the error well disappeared however I have a new one, and still with the value of $WM_PROJECT_DIR :
I don't understand why the variable is ok for the first occurence in Allwmake but not for the second path.
How can i check the value of $WM_PROJECT_DIR in the sudo shell?
Old   July 3, 2017, 13:31
Alexey Matveichev
New error seems to be exactly the same as in your first message.
It depends on configuration, on my laptop, for example, sudo preserves environment.
You can check value of environment variable with
sudo echo $WM_PROJECT_DIR
Old   July 5, 2017, 01:49
Yes it's the same error as before when I replaced the path manually. sudo -E has eliminated the first error (line 7 in Allwmake) but doesn't work after, even so "sudo echo $WM_PROJECT_DIR$" return the good path. Maybe the environment is not well preserved with -E flag?
However I've tried to source the bashrc file in root as you mentioned and the compiling started without any problem. I don't have the time to check if it will go all the way right now, but there is a good chance that my problem is solved.
Thank you
compiling, openfoam
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
