[OpenFOAM.org] Deb packages on Ubuntu 16.04: Problem with bash file
Old   April 17, 2017, 08:09
Default Deb packages on Ubuntu 16.04: Problem with bash file
f.fp is on a distinguished road
I installed OF on Ubuntu 16.04 LTS and it was not working properly. I realised then that two versions of OpenFoam were installed: 4 and -dev, I removed both and I tried to reinstall the former. However, after typing the commands:
sudo apt-get update I got the following error:
> W: GPG error: https://apt.dockerproject.org/repo ubuntu-yakkety
> InRelease: The following signatures couldn't be verified because the
> public key is not available: NO_PUBKEY F76221572C52609D W: The
> repository 'https://apt.dockerproject.org/repo ubuntu-yakkety
> InRelease' is not signed. N: Data from such a repository can't be
> authenticated and is therefore potentially dangerous to use. N: See
> apt-secure(8) manpage for repository creation and user configuration > details.
Furthermore, in my terminal these two messages appear:
bash: /opt/openfoam-dev/etc/bashrc: No such file or directory
bash: /opt/openfoam4/etc/bashr: No such file or directory
And I don't know how to remove them. Can anyone help me to fix this? I would like to perform a correct installation once for all!
f.fp is offline   Reply With Quote
Old   April 17, 2017, 11:51
or the first problem I think I have solved: it is sufficient to type
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys keyNo
where the last "keyNo" is the missing key.
As for the latter problem, opening the bash file and removing the last line(s) the problem desappears!
Old   April 24, 2017, 14:31
Retired Super Moderator
Bruno Santos
Greetings f.fp and welcome to the forum!
Many thanks for letting us know how you solved your problems!
My guess is that you are referring here to the file "~/.bashrc", namely the file ".bashrc" that is your own home folder.
You can then source (active) one of the "bashrc" files for the OpenFOAM version that you want to use. If you want to be able to switch between versions of OpenFOAM, follow the instructions given here: https://openfoamwiki.net/index.php/I...nFOAM_versions
Best regards,
Bruno
bashrc, installation, openfoam 4.0, ubuntu 16.04 lts
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
