[Other] Installing OpenFoam on Windows 7, 32 bit Operating System |
Khan
Rep Power: 9 ![]() |
Dear Friends,
I am tried to download OpenFoam from the their official website for Windows 7 but I failed. The latest downloaded version available on their website is not running on my 32 bit opearting system. It give me corrupted file error message. Any help in this respect will be appreciated please. Thanks in advance |
Uwe Pilz
Rep Power: 15 ![]() |
I use v16.10 from openfoam support without any larger problems. The integration in windows is very good:
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Khan
I thank you Uwe Pilz for your suggestion and help. Let me catch this version and try on my PC.
Kind regards, Khan |
Khan
Dear Uwe Pilz,
I see only "OpenFOAM-for-Windows-17.02v1-win64-install.exe" file on the web page you referred to. Will it work for on 32 bit operating system?. From where I can get verstion 16.10 for 32 bit operating system? Or any version of OpenFoam for 32 bit operating system?. Kind regards, Khan |
Uwe Pilz
You are right, the version need a 64 bit system.
I tried the version 1.5.00b too. It uses a virtual linux machine with a shared folder for connection with windows. That means, the windows integration is more loose. I tried it only at 64 bit systems, and don't know whether ist works with 32 bit systems. I don't have a 32 bit system anymore, so I am interested to hear from you whether it works.
#6 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings to all!
@Khan82: Quote:
Right now, the only solution that I'm aware of is to install a virtualization software and install Ubuntu or some other Linux distribution inside a virtual machine and install OpenFOAM inside it. In the near future, I'm hoping to be able to write instructions for installing ports of OpenFOAM to run on Windows (specifically under the blueCFD-Core project that I work on) to also take into account 32-bit installations, but the downside is that people will have to build OpenFOAM from source code in those situations, which takes somewhere from 2 to 8 hours to do, depending on how old the machine is. But right now I don't have a time estimate of when the instructions will be ready and written. Best regards, Bruno
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
CFD Support's port of OpenFOAM for Windows, version 16.06: file names | Kostas_K | OpenFOAM Running, Solving & CFD | 1 | September 11, 2016 12:25 |
Installing OpenFOAM with SYSTEM MPI while using Third-Party libs | m.culpo | OpenFOAM Installation | 5 | July 3, 2011 03:48 |
Help required with installing openfoam on windows os... | faisal_durr | OpenFOAM | 2 | November 20, 2009 10:13 |
windows operating system | scientist | Main CFD Forum | 8 | November 19, 2004 03:30 |
