[Other] Running OpenFoam on Windows from cmd
Old   March 17, 2017, 05:39
Default Running OpenFoam on Windows from cmd
Mhamad Mahdi Alloush
mahdialloush is on a distinguished road
Hi everyone,
I have so far read a lot of things about docker, machines, containers .. but still I cant run openfoam commands on the windows cmd. I need to run the commands from the typical cmd terminal of windows.
Thanks
mahdialloush is offline   Reply With Quote
Old   March 17, 2017, 06:55
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You may install the windows port from cfd support
http://www.cfdsupport.com/de/openfoam-for-windows.html
The standard is running the program from a windows version of bash. It is possible however, to use the cmd console. You have to set the execution path to all libraries the program requires, that's all.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 17, 2017, 07:04
Thanks. The thing is that I wan to make a batch file which includes a set of commands:
1) start openfoam container
2) go to directory of openfoam case
3) run openfoam solver
So, is it possibe?
Old   March 17, 2017, 13:03
piu58's Avatar
Uwe Pilz
For that, you don't need to use the command shell. The bash will do this as well and without problems with search paths. Simply write a shell script, which is very similar to a batch file of cmd.
Uwe Pilz
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
[Other] How to install OpenFOAM under Windows? lzgwhy OpenFOAM Installation 19 October 7, 2023 05:27
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAM (Linux) in a MS-HPC-Cloud fossy OpenFOAM 6 September 23, 2010 12:48
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
