[OpenFOAM.com] Problems building OF-1.7.x version, Ubuntu 16.04, Gcc-5.4.0 |
February 16, 2017, 12:45 |
Sandip Wadekar
Rep Power: 12 |
Hello foamers
I am using OF-1.7.x version, Ubuntu 16.04, Gcc-5.4.0. I am compiling XiFoam, but i am not getting the error I think, this error is from the thermoPhysicalModels/reactionThermo, but this library is compling fine . can someone help with this problem ? PHP Code:
February 20, 2017, 18:39 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: GCC 5.4.0 is not a supported version to be used for building OpenFOAM 1.7.x. The last known GCC series known to work is GCC 4.5, as reported here: https://openfoamwiki.net/index.php/I...ibility_Matrix
For building OpenFOAM 1.7.1 on Ubuntu 16.04, see the following instructions as a reference of the steps you need to do with 1.7.x: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04
February 22, 2017, 12:11 |
#3 | |
Sandip Wadekar
Rep Power: 12 |
It works fine |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
Problems with Industrial Building Ventilation | jjperez | FLUENT | 0 | February 8, 2012 11:46 |
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x | wyldckat | OpenFOAM Bugs | 18 | October 21, 2010 06:51 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 15:43 |
Problems installin OpenFoam-1.5-dev in Ubuntu 8 | tmata2002 | OpenFOAM Installation | 2 | September 23, 2009 11:50 |
