[OpenFOAM.org] Problems to install openfoam-2.4.0 on Ubuntu 16.04.01LTS
Old   February 19, 2017, 20:35
Default Problems to install openfoam-2.4.0 on Ubuntu 16.04.01LTS
Matheus Monjon
matheusmonjon is on a distinguished road
Hi, i'm a beginner on Ubuntu, and i'm using Ubuntu for CFD Researchs.
I'm trying to install openfoam-2.4.0 on my Ubuntu 16.04.01LTS by following this steps:
https://openfoam.org/download/2-4-0-ubuntu/
But, when i used this comand: sudo apt-get -y install openfoam240
This problem appeared for me:
root@USERNAME:/home/USER# sudo apt-get -y install openfoam240
Lendo listas de pacotes... Pronto
Construindo árvore de dependências
Lendo informação de estado... Pronto
E: Impossível encontrar o pacote openfoam240
My Ubuntu language is portuguese, but on the last line,
the terminal says that is IMPOSSIBLE TO FIND OPENFOAM240 PACKAGE
I followed all steps, but always appeared this error.
Please, someone help me, I really need to fix this to start my Research.
matheusmonjon is offline   Reply With Quote
Old   February 20, 2017, 18:43
Retired Super Moderator
Bruno Santos
Quick answer: The page specifically states that the only supported Ubuntu versions are:
  • 14.04 LTS, codename trusty
  • 15.04, codename vivid
If you want to use OpenFOAM 2.4.0 on Ubuntu 16.04, you will need to build from source code, as instructed in either one of the following pages:
Old   February 22, 2017, 00:52
Matheus Monjon
Thanks, this fix my problems with the correct installation.
But, paraFoam is not running or not installed.
How can I install paraView-4.1?
____________
When run "paraFoam" to solving my case "cavity", this appeared to me:
 matheus@matheus-X550LN:~/OpenFOAM/matheus-2.4.0/run/tutorials/cavity$ paraFoam
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
./Allwclean
./Allwmake
I tryed to fallow this steps, but this message appeared to me:
matheus@matheus-X550LN:~$ cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
matheus@matheus-X550LN:~/OpenFOAM/OpenFOAM-2.4.0/applications/utilities/postProcessing/graphics/PV4Readers$ ./Allwclean
+ wclean libso vtkPV4Readers
wclean vtkPV4Readers
+ PV4blockMeshReader/Allwclean
+ rm -f /home/matheus/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libPV4blockMeshReader*
+ rm -rf PV4blockMeshReader/Make
+ wclean libso vtkPV4blockMesh
wclean vtkPV4blockMesh
+ PV4FoamReader/Allwclean
+ rm -f /home/matheus/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libPV4FoamReader*
+ rm -rf PV4FoamReader/Make
+ wclean libso vtkPV4Foam
wclean vtkPV4Foam
matheus@matheus-X550LN:~/OpenFOAM/OpenFOAM-2.4.0/applications/utilities/postProcessing/graphics/PV4Readers$ ./Allwmake
ERROR: ParaView not found in /home/matheus/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc/ParaView-4.1.0
How can I download ParaView-4.1.0 and how I install it?
I need to fix it for my research. I hope you will help me. Thanks
Last edited by wyldckat; March 25, 2017 at 16:04. Reason: merged posts done a few minutes apart and ordered them to keep it on topic
Old   February 25, 2017, 15:46
João Ferreira
jmdf is on a distinguished road
You need to repeat the step where it installs paraview, it might have failed when you did it the last time:
sed -i -e 's=//#define GLX_GLXEXT_LEGACY=#define GLX_GLXEXT_LEGACY=' \
  ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx
cd $WM_THIRD_PARTY_DIR/ParaView-4.1.0
wget http://www.paraview.org/pipermail/paraview/attachments/20140210/464496cc/attachment.bin -O Fix.patch
patch -p1 < Fix.patch
cd VTK
wget https://github.com/gladk/VTK/commit/ef22d3d69421581b33bc0cd94b647da73b61ba96.patch -O Fix2.patch
patch -p1 < Fix2.patch
cd ../..
#this will take a while... somewhere between 30 minutes to 2 hours or more
./makeParaView4 -python -mpi -python-lib /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 > log.makePV 2>&1
If this doesn't help, give more information about your environment, such as OS you are using, etc.
jmdf is offline   Reply With Quote
install, openfoam 2.4.0 help, packages, ubuntu 16.04 lts
[OpenFOAM.org] error in installation OpenFOAM 2.4.0 in Ubuntu 14.04 alimea OpenFOAM Installation 2 August 9, 2018 08:12
[OpenFOAM.org] Problems installing OpenFOAM 2.3.1 in Ubuntu 12.04 masoudshao OpenFOAM Installation 10 August 9, 2018 07:13
[OpenFOAM.org] Trying to install openfoam 2.4.0 on fedora 26 harsha_kulkarni OpenFOAM Installation 1 August 18, 2017 17:31
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 arieljeds OpenFOAM Installation 6 August 19, 2015 08:39
Problems installing SVN in Ubuntu (for later installing PyFoam for OpenFOAM) immortality Lounge 2 May 24, 2014 04:05
