[OpenFOAM.org] Problems installing OpenFOAM 2.1.0 on CentOS 6.2 |
December 23, 2016, 08:38 |
vin
Rep Power: 16 |
I want to install openfoam-2.1.0.
But I get below error OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam /usr/bin/ld: cannot find -lfiniteVolume collect2: ld returned 1 exit status make[2]: *** [/home/internal/cfd/vinayas/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam] Error 1 make[2]: Leaving directory `/home/internal/cfd/vinayas/OpenFOAM/OpenFOAM-2.1.0/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam' make[1]: *** [solidEquilibriumDisplacementFoam] Error 2 make[1]: Target `application' not remade because of errors. make[1]: Leaving directory `/home/internal/cfd/vinayas/OpenFOAM/OpenFOAM-2.1.0/applications/solvers/stressAnalysis' make: *** [stressAnalysis] Error 2 make: Target `application' not remade because of errors. My machine configuration is LSB Version: :core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarchrinting-4.0-amd64rinting-4.0-noarch Distributor ID: CentOS Description: CentOS release 6.2 (Final) Release: 6.2 Codename: Final Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 16 On-line CPU(s) list: 0-15 Thread(s) per core: 1 Core(s) per socket: 8 CPU socket(s): 2 NUMA node(s): 2 Vendor ID: GenuineIntel CPU family: 6 Model: 45 Stepping: 7 CPU MHz: 2593.804 BogoMIPS: 5186.86 Virtualization: VT-x L1d cache: 32K L1i cache: 32K L2 cache: 256K L3 cache: 20480K NUMA node0 CPU(s): 0-7 NUMA node1 CPU(s): 8-15 |
December 23, 2016, 09:47 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Detailed installation steps are available for installing OpenFOAM 2.1.1 in CentOS 6.3: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.3
Please run the following commands: Code:
./Allwmake > log.make 2>&1 gzip < log.make > log.make.gz
[OpenFOAM.org] Installing OpenFOAM 2.4.0 on CentOS 6.6 | kyrox | OpenFOAM Installation | 21 | May 30, 2016 19:49 |
Problems installing OpenFOAM 1.6-ext on Ubuntu 12.04 | arashfluid | OpenFOAM Installation | 3 | July 21, 2013 07:36 |
Installing OpenFOAM 2.1.1 on CentOS 5.x | phuchuynh | OpenFOAM Installation | 1 | October 10, 2012 17:58 |
gcc (OpenFOAM 2.1.0 on CentOS 5) | sukye | OpenFOAM Installation | 10 | May 5, 2012 11:35 |
Re : Problem Installing OpenFOAM on Centos -5.3 | mohanphy | OpenFOAM Installation | 1 | February 7, 2010 20:09 |
