[OpenFOAM.com] v1606+ Run Folder
Old   December 15, 2016, 18:27
Default v1606+ Run Folder
Deutschland
JSMOKA is on a distinguished road
Hi Friends,
i have installed OpenFOAM-v1606+ on my Ubuntu 14.04 LTS.
In "opt"'s folder i have allready OpenFoam and ThirdParty.
1- I should create an new folder with name "OpenFOAM" in directory "home".
2- And in "Home/OpenFOAM" folder i should create new folder " user-v1606+ ".
3- And in folder "Home/OpenFOAM/user-v1606+" with "mkdir -p $FOAM_RUN" should i create Folder "run" for post processing.
when i give this command in terminal, but it doesn't work . i receive this Info in Terminal "„mkdir --help“"
what shoul i do?
JSMOKA is offline   Reply With Quote
Old   December 15, 2016, 19:53
Retired Super Moderator
Bruno Santos
Quick answer: This means that the OpenFOAM-v1606+ environment is not activated. Did you run the following command?
source /opt/OpenFOAM/OpenFOAM-v1606+/etc/bashrc
And what steps did you take to install it in "/opt"?
Old   December 15, 2016, 20:19
Deutschland
Hi, i did fallowing steps:
1- sudo apt-get install build-essential flex bison cmake zlib1g-dev libboost-system-dev libboost-thread-dev libopenmpi-dev openmpi-bin gnuplot libreadline-dev libncurses-dev libxt-dev
2- sudo apt-get install qt4-dev-tools libqt4-dev libqt4-opengl-dev freeglut3-dev libqtwebkit-dev
3- sudo apt-get install libgmp-dev libmpfr-dev
4- mkdir -p /opt/OpenFOAM
5- tar xvzf ThirdParty-v1606Plus.tar.gz -C /opt/OpenFOAM/
6- tar xvzf OpenFOAM-v1606Plus.tar.gz -C /opt/OpenFOAM/
7- echo ". /opt/OpenFOAM/OpenFOAM-v1606+/etch/bashrc" >> .bashrc
Old   December 15, 2016, 21:18
Bruno Santos
Quick answer: You have a typo in the last line:
It's "etc", not "etch"
Try running:
. /opt/OpenFOAM/OpenFOAM-v1606+/etc/bashrc
echo $FOAM_RUN
If it shows an empty line, then it's not working yet. If it shows the path to the "run" folder, then you need to edit the file ".bashrc" in your home folder and correct the respective line.
Old   December 16, 2016, 05:23
Deutschland
thank you very very much and "run" is there... but "then you need to edit the file ".bashrc" in your home folder and correct the respective line. " i donthave any idea what should i do...how can i repair the file in .bashrc..i don't have too much experience with bash.
ich finde .bashrc with this commnad: "ls -a |grep bashrc" and with geit ~/bashrc i edited etch in etc but run is not to finde
Old   December 18, 2016, 20:47
Bruno Santos
Quick answer: See the following wiki page for more details: http://openfoamwiki.net/index.php/In...with_the_Shell
But in a nutshell, run this command:
gedit ~/.bashrc
Notice that there is a tilde '~' and a dot '.'
Then scroll to the end of the file and look for the references to "v1606+".
chtMultiRegionSimpleFoam: crash on parallel run student666 OpenFOAM Running, Solving & CFD 3 April 20, 2017 12:05
User fortran to input/output file in a parallel run doublestrong CFX 5 March 31, 2017 09:15
OpenFOAM can't be run in parallel in cluster sibo OpenFOAM Running, Solving & CFD 4 February 21, 2017 17:29
parallel run is slower than serial run (pimpleFoam) !!! mechy OpenFOAM 18 August 17, 2016 18:19
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
