[OpenFOAM.org] OpenFOAM-4.1 compile error on openSUSE Tumbleweed |
December 8, 2016, 10:59 |
Jason
Rep Power: 11 |
Hi there
Error surfaces while I was compiling OpenFOAM-4.1 with gcc-6.2 on the Tumbleweed. I haven't seen any issues like that. Please help Code:
In file included from /home/zbli/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/postProcess.H:129:0, from coldEngineFoam.C:47: ../XiFoam/createFields.H: In function ‘int main(int, char**)’: ../XiFoam/createFields.H:3:9: error: ‘psiuReactionThermo’ was not declared in this scope autoPtr<psiuReactionThermo> pThermo ^~~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:3:27: error: template argument 1 is invalid autoPtr<psiuReactionThermo> pThermo ^ ../XiFoam/createFields.H:5:5: error: ‘psiuReactionThermo’ is not a class, namespace, or enumeration psiuReactionThermo::New(mesh) ^~~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:7:21: error: ‘thermo’ was not declared in this scope psiuReactionThermo& thermo = pThermo(); ^~~~~~ ../XiFoam/createFields.H:7:38: error: ‘pThermo’ cannot be used as a function psiuReactionThermo& thermo = pThermo(); ^ ../XiFoam/createFields.H:10:1: error: ‘basicMultiComponentMixture’ was not declared in this scope basicMultiComponentMixture& composition = thermo.composition(); ^~~~~~~~~~~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:10:29: error: ‘composition’ was not declared in this scope basicMultiComponentMixture& composition = thermo.composition(); ^~~~~~~~~~~ In file included from /home/zbli/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/postProcess.H:129:0, from coldEngineFoam.C:47: ../XiFoam/createFields.H:93:9: error: ‘laminarFlameSpeed’ was not declared in this scope autoPtr<laminarFlameSpeed> unstrainedLaminarFlameSpeed ^~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:93:26: error: template argument 1 is invalid autoPtr<laminarFlameSpeed> unstrainedLaminarFlameSpeed ^ ../XiFoam/createFields.H:95:5: error: ‘laminarFlameSpeed’ is not a class, namespace, or enumeration laminarFlameSpeed::New(thermo) ^~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:93:28: warning: unused variable ‘unstrainedLaminarFlameSpeed’ [-Wunused-variable] autoPtr<laminarFlameSpeed> unstrainedLaminarFlameSpeed ^~~~~~~~~~~~~~~~~~~~~~~~~~~ make[2]: *** [/home/zbli/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8: /home/zbli/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/coldEngineFoam/coldEngineFoam.o] Error 1 make[1]: *** [/home/zbli/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: coldEngineFoam] Error 2 make: *** [/home/zbli/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: combustion] Error 2 |
December 10, 2016, 00:09 |
Jason
Rep Power: 11 |
Hi, anyone can help?
I recompiled this with different versions of gcc(4.9.4) and openmpi(1.8/1.10) and it didn't help any. I guess I must have something missed here. But I did follow the instruction of Wiki for Suse installation. I'm totally confused with this issue and have no idea how I could run into this. BTW, I tried to compile swak4Foam for the OF2.3.0version which I have in my PC as an alternative to deal with postProcessing, but also failed anyway. |
December 13, 2016, 17:13 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Sorry, I saw this thread during the weekend, but didn't manage to find the time needed to look into this before.
Nonetheless, we are already addressing this in the bug tracker here: https://bugs.openfoam.org/view.php?id=2386 As for the problem you had in building swak4Foam, more details are needed, namely which installation instructions you've followed and which version you've downloaded.
January 15, 2017, 07:16 |
Daniel Deising
Hi Wyldcat,
thx very much for the Issue Tracking report! I had the same problem as reported by zbli on my Ubuntu 12.04 LTS and resetting CPLUS_INCLUDE_PATH solved the problem for me. The path had a leading colon in front. Resetting the variable without the colon fixed the issue. Best, Daniel |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM 4.1 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 0 | October 13, 2016 07:42 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 12:50 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 04:19 |
OpenFOAM Live USB based on openSUSE 11.1 created with SUSE Studio | alberto | OpenFOAM | 40 | May 23, 2010 17:15 |
