September 28, 2016, 17:42 |
OpenFOAM stopped working
Matt
Rep Power: 10 |
Dear all,
I have recently installed (compiled) OpenFOAM 4 on ubuntu 16.0.4 LTS successfully and it was working very fine. In my .bashrc file I had created an alias as below: alias of4c='source /opt/openfoam4Com/OpenFOAM-4.0/etc/bashrc' Today when I execute the of4c in order to use OpenFOAM 4, I got the following lines in the terminal: /home/m _foamSource: command not found _foamEval: command not found _foamSource: command not found _foamSource: command not found _foamSource: command not found _foamSource: command not found _foamSource: command not found _foamSource: command not found _foamSource: command not found /home/m I am very amazed! because it was working fine just till yesterday!. I have no idea what has went wrong. Could you please give advice? Thanks, Matt |
September 29, 2016, 16:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick questions:
October 2, 2016, 11:34 |
Matt
Rep Power: 10 |
Hi Bruno,
Thanks for your response. Here are the answers to your questions: 1. /opt/openfoam4Com is a real path 2. Yes 3. This is the output of the results: Code:
declare -x FOAMY_HEX_MESH="yes" declare -x FOAM_APP="/opt/openfoam4Com/OpenFOAM-4.0/applications" declare -x FOAM_APPBIN="/opt/openfoam4Com/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/bin" declare -x FOAM_ETC="/opt/openfoam4Com/OpenFOAM-4.0/etc" declare -x FOAM_EXT_LIBBIN="/opt/openfoam4Com/ThirdParty-4.0/platforms/linux64GccDPInt32/lib" declare -x FOAM_INST_DIR="/opt/openfoam4Com" declare -x FOAM_JOB_DIR="/opt/openfoam4Com/jobControl" declare -x FOAM_LIBBIN="/opt/openfoam4Com/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/lib" declare -x FOAM_MPI="openmpi-system" declare -x FOAM_RUN="/home/m/OpenFOAM/m-4.0/run" declare -x FOAM_SETTINGS="" declare -x FOAM_SIGFPE="" declare -x FOAM_SITE_APPBIN="/opt/openfoam4Com/site/4.0/platforms/linux64GccDPInt32Opt/bin" declare -x FOAM_SITE_LIBBIN="/opt/openfoam4Com/site/4.0/platforms/linux64GccDPInt32Opt/lib" declare -x FOAM_SOLVERS="/opt/openfoam4Com/OpenFOAM-4.0/applications/solvers" declare -x FOAM_SRC="/opt/openfoam4Com/OpenFOAM-4.0/src" declare -x FOAM_TUTORIALS="/opt/openfoam4Com/OpenFOAM-4.0/tutorials" declare -x FOAM_USER_APPBIN="/home/m/OpenFOAM/m-4.0/platforms/linux64GccDPInt32Opt/bin" declare -x FOAM_USER_LIBBIN="/home/m/OpenFOAM/m-4.0/platforms/linux64GccDPInt32Opt/lib" declare -x FOAM_UTILITIES="/opt/openfoam4Com/OpenFOAM-4.0/applications/utilities" declare -x LD_LIBRARY_PATH="/opt/openfoam4Com/ThirdParty-4.0/platforms/linux64Gcc/gperftools-svn/lib:/opt/openfoam4Com/ThirdParty-4.0/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0:/opt/openfoam4Com/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/opt/openfoam4Com/ThirdParty-4.0/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/openmpi/lib:/home/m/OpenFOAM/m-4.0/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam4Com/site/4.0/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam4Com/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam4Com/ThirdParty-4.0/platforms/linux64GccDPInt32/lib:/opt/openfoam4Com/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/lib/dummy" declare -x PATH="/opt/openfoam4Com/ThirdParty-4.0/platforms/linux64Gcc/gperftools-svn/bin:/opt/openfoam4Com/ThirdParty-4.0/platforms/linux64Gcc/ParaView-5.0.1/bin:/home/m/OpenFOAM/m-4.0/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam4Com/site/4.0/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam4Com/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam4Com/OpenFOAM-4.0/bin:/opt/openfoam4Com/OpenFOAM-4.0/wmake:/home/m/bin:/home/m/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" declare -x PV_PLUGIN_PATH="/opt/openfoam4Com/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/lib/paraview-5.0" declare -x PWD="/home/m/OpenFOAM/m-4.0/run" declare -x WM_ARCH="linux64" declare -x WM_ARCH_OPTION="64" declare -x WM_CC="gcc" declare -x WM_CFLAGS="-m64 -fPIC" declare -x WM_COMPILER="Gcc" declare -x WM_COMPILER_LIB_ARCH="64" declare -x WM_COMPILER_TYPE="system" declare -x WM_COMPILE_OPTION="Opt" declare -x WM_CXX="g++" declare -x WM_CXXFLAGS="-m64 -fPIC -std=c++0x" declare -x WM_DIR="/opt/openfoam4Com/OpenFOAM-4.0/wmake" declare -x WM_LABEL_OPTION="Int32" declare -x WM_LABEL_SIZE="32" declare -x WM_LDFLAGS="-m64" declare -x WM_LINK_LANGUAGE="c++" declare -x WM_MPLIB="SYSTEMOPENMPI" declare -x WM_OPTIONS="linux64GccDPInt32Opt" declare -x WM_OSTYPE="POSIX" declare -x WM_PRECISION_OPTION="DP" declare -x WM_PROJECT="OpenFOAM" declare -x WM_PROJECT_DIR="/opt/openfoam4Com/OpenFOAM-4.0" declare -x WM_PROJECT_INST_DIR="/opt/openfoam4Com" declare -x WM_PROJECT_USER_DIR="/home/m/OpenFOAM/m-4.0" declare -x WM_PROJECT_VERSION="4.0" declare -x WM_THIRD_PARTY_DIR="/opt/openfoam4Com/ThirdParty-4.0" Code:
alias of4='source /opt/openfoam4/etc/bashrc' alias of4c='source /opt/openfoam4Com/OpenFOAM-4.0/etc/bashrc' Thanks, Matt Last edited by wyldckat; November 13, 2016 at 18:13. Reason: Added [CODE][/CODE] markers |
November 13, 2016, 18:26 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Matt,
My apologies for the delay in getting back to you on this, but unfortunately flew by and I still haven't managed to deduce a solution or reasoning for this... wait... there were some recent details that came up which might explain this. I've documented some of them here: http://bugs.openfoam.org/view.php?id=2311 Technically I don't see anything in the output of export that would point to the problem with "GREP_OPTIONS", so that shouldn't be it... oh, wait, I asked you to run export with grep, so the output isn't complete. OK, anyway, if you haven't fixed this already, let's try fixing this the other way around: Quote:
alias of4='[ -n "$WM_PROJECT_DIR" ] && source $WM_PROJECT_DIR/etc/config.sh/unset; source /opt/openfoam4/etc/bashrc' alias of4c='[ -n "$WM_PROJECT_DIR" ] && source $WM_PROJECT_DIR/etc/config.sh/unset; source /opt/openfoam4Com/OpenFOAM-4.0/etc/bashrc' What I've done here is embed the command used by the alias "wmUnset", which you can see by running: Code:
alias wmUnset Code:
alias wmUnset='. $WM_PROJECT_DIR/etc/config.sh/unset' Code:
ls -l /bin/sh ls -l /bin/bash which sh Bruno |
openfoam |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 11:19 |
Possible to simulate a working Centrifugal Compressor for jet engine on OpenFOAM? | fazlur | OpenFOAM | 1 | August 21, 2013 05:30 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
