[OpenFOAM.org] 4.0: Problems compiling ParaView on Ubuntu 16.04 |
Rishabh Golchha
Rep Power: 9 ![]() |
OK. Thanks a a lot
So now I am trying to install OpenFOAM 4.0. I am at the compilation stage. I have a couple of queries. Is it necessary to have ParaView. If yes, could you please provide bit more detailed steps on how to compile it. I tried by first changing directory to folder "/OpenFOAM/ThirdParty-4.0" and then typing Code:
./makeParaView Code:
./makeParaView: 36: ./makeParaView: wmakeCheckPwd: not found Error: Current directory is not $WM_THIRD_PARTY_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. Code:
echo $WM_THIRD_PARTY_DIR Code:
/home/rishabh/OpenFOAM/ThirdParty-4.0 Also, I am tried to compile OpenFOAM without ParaView. I type Code:
./Allwmake Code:
./Allwmake: 7: .: Can't open /home/rishabh/OpenFOAM/OpenFOAM-4.0/wmake/scripts/AllwmakeParseArguments Last edited by RishabhG; September 18, 2016 at 05:08. |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer:
[OpenFOAM.org] Problems installing OpenFOAM 2.4.0 on Ubuntu 16.04 | donminoti | OpenFOAM Installation | 13 | January 13, 2021 17:07 |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[OpenFOAM.org] Problems with Paraview (OpenFOAM 2.4.0 from source code in Ubuntu 14.04) | Gerrit | OpenFOAM Installation | 4 | August 15, 2015 11:05 |
[Other] Which versions of OpenFoam and Paraview are suitable for Ubuntu 14.04 LTS Trusty Tahr | Asghari_M | OpenFOAM Installation | 4 | February 4, 2015 15:47 |
OF-1.6-ext: compiling fails on ubuntu 12.10 | A.Wendy | OpenFOAM Installation | 1 | March 22, 2013 06:47 |
