[OpenFOAM.org] OpenFOAM-dev. minData.H not found
Old   August 24, 2016, 15:55
Default OpenFOAM-dev. minData.H not found
Svensen is on a distinguished road
I've tried to compile OpenFOAM-dev, but when compiling the file "/src/parallel/decompose/decompositionMethods/decompositionMethod/decompositionMethod.C"
an error occurs that "minData.H" is not found.
Does anybody know how to solve this issue ? Thanks.
Svensen is offline   Reply With Quote
Old   August 24, 2016, 21:44
Retired Super Moderator
Bruno Santos
Quick note: I know that Svensen has already sorted this out, as detailed here: http://bugs.openfoam.org/view.php?id=2217
So for future readers: Essentially the problem was that the main Allwmake script should have been executed with the "-update" option. This is detailed at the following pages:
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
[Other] cgnsToFoam problems with "QUAD_4" cells lentschi OpenFOAM Meshing & Mesh Conversion 1 March 9, 2011 05:49
