[OpenFOAM.com] v1606+ Compiling/installing problems
Like Tree3Likes
Old   September 17, 2016, 09:13
Retired Super Moderator
Bruno Santos
Originally Posted by sage View Post
I was able to simply install OpenFoam-4.0 from openfoam.org. That is much easier to install with just a few lines of code.
I think you're missing the point here. The people on this thread are installing OpenFOAM+ v1606+ because they are looking for features that currently are still only available in that version and which have not been donated yet to the OpenFOAM Foundation.
Old   September 17, 2016, 10:23
sage is on a distinguished road
I totally get your point. I also tried installing v1606+ but there were so many errors propping up, i decided to shift. So it was a suggestion for those whose deadlines were nearby for work submission otherwise thank you, i will shift to the latest version too soon enough
sage is offline   Reply With Quote
Old   September 17, 2016, 10:34
Bruno Santos
Ah, OK, I didn't have enough information on what was your point of view when you wrote the previous post.
Keep in mind that OpenFOAM 4.0 and OpenFOAM+ v1606+ are mostly compatible, but have slightly different development lines, as indicated in the release notes for v1606+: http://openfoam.com/version-v1606+/
Includes all Foundation code changes to commit level 449a9ec 21-04-2016
which means that the last point of synchronization was roughly 2 months before OpenFOAM 4.0 was released. The next release of OpenFOAM+, v1612+, should already include everything that OpenFOAM 4.x has got and more.
In addition, you can have more than one version of OpenFOAM/OpenFOAM+ installed. Details on how to have more than one version can be found here: http://openfoamwiki.net/index.php/In...nFOAM_versions
Old   September 17, 2016, 18:44
Hello Bruno!
I succesfully downloaded and installed OF v1606+. However, there was no docker folder created in the home directory and i cant seem to find where the data files are located. I have to type
cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity .
to first transfer the case files to my home directory before i can run the case. This is a very weird issue.
Old   September 17, 2016, 19:57
Bruno Santos
Hello Bruno!
Quick question: Which installation instructions did you follow and in which operating system did you install (Linux, Mac OS X or Windows)?
Old   September 18, 2016, 02:04
Hey! Yeah I have Ubuntu 14.04 and I followed the instructions on the binary installation page of openfoam.com
Old   September 18, 2016, 17:32
Bruno Santos
OK, so you followed the instructions meant for Linux that are provided here: http://www.openfoam.com/download/install-binary.php
Hello Bruno!
Here is what I get when I run the startOpenFoam+ script:
ofuser@themachine:~/OpenFOAM/OFplus_scripts$ ./startOpenFoam+
non-network local connections being added to access control list
of_v1606_plus
/opt/OpenFOAM
bash-4.1$
I don't know what you were expecting or what you are seeing. The instructions on the binary install page state which commands should be used to get started with running a tutorial case... although I didn't spot a bug right now, namely that the wrong commands are used for running the cavity case... the correct commands are:
mkdir -p $FOAM_RUN
run
cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity .
cd cavity
blockMesh
icoFoam
paraFoam
It's just the folder path itself for the original case that changed a bit.
Old   September 19, 2016, 00:04
of_v1606_plus
/opt/OpenFOAM
bash-4.1$
mkdir -p $FOAM_RUN
run
cd cavity
blockMesh
icoFoam
paraFoam
Hi! I just wanted to know the path of the installation directory. There isn't any folder that holds all the original files of OF1606 like the 'opt' does for the previous versions.
Regards,
Gohar Shoukat
Old   September 19, 2016, 05:24
Paul Palladium
Fauster is on a distinguished road
Hi !
Same error on Ubuntu 14.04 LTS
HTML Code:
/usr/bin/ld: cannot find -lrandomProcesses
I tried this (post of Bruno) :
cd $WM_THIRD_PARTY_DIR sed -i -e 's=unset _foamAddPath=unset -f _foamAddPath=' makeFFTW cd $WM_PROJECT_DIR ./Allwmake -j
This helped a bit but I still have some issues (translate from French to English):
Warning: The file /opt/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/utilities/postProcessing/graphics/PVReaders/PVFoamReader/PVFoamReader/doc/*.html doesn't exist ! File not include.
Warning: The file /opt/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/utilities/postProcessing/graphics/PVReaders/PVFoamReader/PVFoamReader/doc/*.css doesn't exist !File not include.
Warning: The file /opt/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/utilities/postProcessing/graphics/PVReaders/PVFoamReader/PVFoamReader/doc/*.png doesn't exist ! File not include.
Warning: The file /opt/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/utilities/postProcessing/graphics/PVReaders/PVFoamReader/PVFoamReader/doc/*.jpg doesn't exist ! File not include.
After that the compilation goes on and I run successfully the tutorial pitzDaily.
What are those missing files ? Can I even use OpenFoam (or paraFoam, it seems to be a graphics problem) without stability problem ?
Regards
Fauster is offline   Reply With Quote
Old   September 19, 2016, 17:09
Bruno Santos
Quick answer: Those are just warnings. You can make sure if everything is already, if you run the Allwmake script again.
Old   September 20, 2016, 09:19
Paul Palladium
Thanks wyldckat,
In deed it seems to be ok..
So on Ubuntu 14.04 LTS with the helpful post of Bruno I manage to install successfully OFv1606+.
Old   September 26, 2016, 06:27
Viraj Belekar
viraj20feb is on a distinguished road
Greetings!
I tried installing OpenFOAM v1606+ on Ubuntu 16.04. But I was not successful in installing the same. I followed the steps from this link : https://openfoamwiki.net/index.php/I...1606%2B/Ubuntu
./Allwmake -j 4 > log.make 2>&1
The above command stops in between as I suppose there might be some error. When I try :
icoFoam -help
I get the output: icoFoam: command not found. I have attached my log file as well
Please reply
viraj20feb is offline   Reply With Quote
Old   September 26, 2016, 19:06
Bruno Santos
Quick answer: Please see my previous post #17: http://www.cfd-online.com/Forums/ope...tml#post617893 - post #17
Old   October 11, 2016, 09:23
Default Cannot find -l randomProcesses
  #34
Balkrishna Patankar
balkrishna is on a distinguished road
I am getting this error :
/usr/bin/ld cannot find -lrandomProcesses
version OpenFOAM-v1606+ downloaded 11/10/2016 running on VirtualBox , Ubuntu 16.04 . Is there any way to fix it ?
Thanks,
balkrishna is offline   Reply With Quote
Old   October 16, 2016, 10:49
Bruno Santos
Quick answer: See post #12 on this thread: http://www.cfd-online.com/Forums/ope...tml#post617450
Old   October 19, 2016, 14:19
Naresh Yathuru
Naresh yathuru is on a distinguished road
Hi Foamers,
Please have a look at the compilation prolem I have under the link below.
It is familiaar but confusing. It is similar to the one mentioned in #17 but a little more complicated.
http://www.cfd-online.com/Forums/ope...it-labels.html
Thank you
Best Regards,
Naresh
Naresh yathuru is offline   Reply With Quote
Old   September 13, 2018, 05:49
Default How can I fix the error in the ubuntu:16.04 container with mpich
  #37
Alexis Espinosa
alexisespinosa is on a distinguished road
Dear Bruno,
This same error appeared when installing v1606+ in ubuntu:16.04 container with system mpich:
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/randomProcesses/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/finiteVolume/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/meshTools/lnInclude -IlnInclude -I. -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/OpenFOAM/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/DNS/dnsFoam/dnsFoam.o -L/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib \
    -lrandomProcesses -lfiniteVolume -lmeshTools -lOpenFOAM -ldl  \
     -lm -o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/dnsFoam
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/applications/solvers/combustion/PDRFoam
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -IXiModels/XiModel -IXiModels/XiEqModels/XiEqModel -IXiModels/XiGModels/XiGModel -IPDRModels/dragModels/PDRDragModel -IlaminarFlameSpeed/SCOPE -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/engine/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/thermophysicalModels/specie/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/transportModels/compressible/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/thermophysicalModels/basic/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/thermophysicalModels/reactionThermo/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/TurbulenceModels/compressible/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/thermophysicalModels/laminarFlameSpeed/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/finiteVolume/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/dynamicFvMesh/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/dynamicMesh/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/meshTools/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/triSurface/lnInclude  -IlnInclude -I. -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/OpenFOAM/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-v1606+/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiModel/XiModel.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiModel/XiModelNew.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/fixed/fixed.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/algebraic/algebraic.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/transport/transport.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiEqModels/XiEqModel/XiEqModel.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiEqModels/XiEqModel/XiEqModelNew.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiEqModels/Gulder/Gulder.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiEqModels/instabilityXiEq/instabilityXiEq.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiEqModels/SCOPEBlendXiEq/SCOPEBlendXiEq.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiEqModels/SCOPEXiEq/SCOPEXiEq.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiGModels/XiGModel/XiGModel.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiGModels/XiGModel/XiGModelNew.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiGModels/KTS/KTS.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/XiModels/XiGModels/instabilityG/instabilityG.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/PDRModels/turbulence/PDRkEpsilon/PDRkEpsilon.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/PDRModels/dragModels/PDRDragModel/PDRDragModel.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/PDRModels/dragModels/PDRDragModel/PDRDragModelNew.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/PDRModels/dragModels/basic/basic.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/PDRModels/XiEqModels/basicXiSubXiEq/basicXiSubXiEq.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/PDRModels/XiGModels/basicXiSubG/basicXiSubG.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/laminarFlameSpeed/SCOPE/SCOPELaminarFlameSpeed.o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/applications/solvers/combustion/PDRFoam/PDRFoam.o -L/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib \
    -lengine -lmeshTools -lturbulenceModels -lcompressibleTurbulenceModels -lcompressibleTransportModels -lfluidThermophysicalModels -lreactionThermophysicalModels -lspecie -llaminarFlameSpeedModels -lfiniteVolume -ldynamicFvMesh -lfvOptions -lOpenFOAM -ldl  \
     -lm -o /home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/PDRFoam
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Waitall'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Abort'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Get_count'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Comm_create'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Group_incl'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Init'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Probe'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Comm_group'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Send'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Allreduce'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Buffer_detach'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Bsend'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Irecv'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Recv'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Comm_free'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Wait'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Test'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Isend'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Alltoall'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Finalize'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Buffer_attach'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Comm_size'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Group_free'
/home/ofuser/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/mpi-system/libPstream.so: undefined reference to `MPI_Comm_rank'
collect2: error: ld returned 1 exit status
I tried the fix you mentioned (and also mentioned in https://openfoamwiki.net/index.php/I...1606%2B/Ubuntu) :
./Allwmake > log.make 2>&1
wmREFRESH
And also define MPI_ROOT etc as explained here:
https://bugs.openfoam.org/view.php?id=1167
export MPI_ROOT=/usr
export MPI_ARCH_FLAGS="-DMPICH_SKIP_MPICXX"
export MPI_ARCH_INC="-I/usr/include/mpich"
export MPI_ARCH_LIBS="-L/usr/lib/x86_64-linux-gnu -lmpich"
But the error persists. We are sort of obliagated to use mpich because we want to use the container in a HPC system. I understand that these tricks have worked for openmpi, but can you guide us to make it work with mpich?
Should we use another linux container (possibly centos)? (still we are obligated to use mpich and v1606+)
Thanks a lot!
Alexis
alexisespinosa is offline   Reply With Quote
Old   September 30, 2018, 09:20
Bruno Santos
Greetings Alexis,
My apologies, but I've only managed to take a look into this now. I don't know if you've solved that problem or if you went with another container?
Although I'm intrigued as to why you couldn't build OpenFOAM v1606+ directly on the HPC platform, but I guess that the container can be built outside of the HPC platform, hence the practicality of it...
OK, I still use Ubuntu 16.04 on my machine at home and happened to still have v1606+ built on it, so I was able to do a quick test on these following steps:
  1. Installed MPICH with the following commands:
    sudo apt-get install libmpich-dev
  2. Create the file "$WM_PROJECT_DIR/etc/prefs.sh" with the following content:
    export WM_MPLIB=SYSTEMMPI
  3. Activate/refresh the OpenFOAM v1606+ environment if you haven't already, e.g.:
    source path_to_OF/OpenFOAM-v1606+/etc/bashrc
    # Or to refresh:
    wmREFRESH
  4. Then I built the "libPstream" library with the new MPI:
    src
    cd Pstream
    ./Allwmake
  5. Then I tried building the PDRFoam solver that you mentioned:
    sol
    cd combustion/PDRFoam/
    wclean
    export WM_NCOMPPROCS=4
    wmake
    the export line was to use 4 cores for compiling faster...
And it worked just fine... so I'm guessing that you missed the need to also change the value for "WM_MPLIB"?
Best regards,
Bruno
installation, openfoam-v1606+
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
