[OpenFOAM.com] v1606+ Installation on Mac OS El Captain using Docker
Old   July 24, 2016, 03:44
Default v1606+ Installation on Mac OS El Captain using Docker
Karim Hassanieh
Karimh89 is on a distinguished road
Dears
Hope all is well I have been recently trying to install the binaries of open-foam using docker as described in (http://www.openfoam.com/download/install-binary.php). The osx version im using is el captain, everything goes smoothly after downloading and I run these commands :
mkdir -p $FOAM_RUN
run
cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity .
and they are ok
but when I enter blockMesh or icoFoam command i receve "command not found"
What could possibly the problem be ? I would apreciate your solve as I really would like to have open foam installed on my osx
Karimh89 is offline   Reply With Quote
Old   August 1, 2016, 09:49
Default Configure bash entry
Jaydeep
jaydeep is on a distinguished road
I believe you have not added the bash entry.
jaydeep is offline   Reply With Quote
Old   August 2, 2016, 08:33
Karim Hassanieh
Could you kindly explain how that can be done ? Adding the bash entry that is ..Sorry I'm just new to the process and I'm not so familiar would appreciate it much
Old   September 15, 2016, 15:29
pgh
Pawan Ghildiyal
pgh is on a distinguished road
Hi
Are you able to resolve the issue yet. ? Note that install docker toolbox in Mac and not docker (which run natively on machine).
https://docs.docker.com/engine/insta...docker-toolbox.
Also , if you have installed docker-toolbox , then click on docker quick start terminal and
type command 'docker images' and 'docker ps -a' and post the output here
pgh is offline   Reply With Quote
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker u2berggeist OpenFOAM Installation 1 July 10, 2018 03:58
[Other] Installation of OpenFOAM: Docker or not Docker? zt49 OpenFOAM Installation 2 December 22, 2016 11:38
[OpenFOAM.com] Docker OpenFOAM install error on Mac OS X dersh OpenFOAM Installation 10 May 6, 2016 13:49
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
Installation Guide for OpenFOAM-1.6-ext on Mac OS X Mountain Lion BernhardGrieser OpenFOAM Installation 4 October 26, 2013 16:39
