[foam-extend.org] issues with extend-3.2 installation on ubuntu |
July 18, 2016, 09:58 |
jingjing cao
Rep Power: 13 |
Hello Foams,
I try to install foam-extend-3.2 on ubuntu but I failed. This is what I got when I run foamInstallationTest cjjjoy@DEVONIAN:~/foam/foam-extend-3.2$ foamInstallationTest Executing /home/cjjjoy/foam/foam-extend-3.2/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: DEVONIAN OS: Linux version 3.16.0-59-generic ------------------------------------------------------------------------------- Checking main foam-extend env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/cjjjoy/foam yes yes $WM_PROJECT_USER_DIR /home/cjjjoy/foam/cjjjoy-3.2 no no $WM_THIRD_PARTY_DIR ...jjoy/foam/foam-extend-3.2/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the foam-extend env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/cjjjoy/foam/foam-extend-3.2 yes yes yes $FOAM_APPBIN ...3.2/applications/bin/linux64GccDPOpt yes yes yes $FOAM_SITE_APPBIN ...oy/foam/site/3.2/bin/linux64GccDPOpt no no $FOAM_USER_APPBIN ...3.2/applications/bin/linux64GccDPOpt no no $WM_DIR /home/cjjjoy/foam/foam-extend-3.2/wmake yes yes yes ------------------------------------------------------------------------------- Checking the foam-extend env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN .../foam-extend-3.2/lib/linux64GccDPOpt yes yes yes $FOAM_SITE_LIBBIN ...oy/foam/site/3.2/lib/linux64GccDPOpt no no $FOAM_USER_LIBBIN .../foam/cjjjoy-3.2/lib/linux64GccDPOpt no no $MPI_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of foam-extend Supplied version: 4.3.3 User version : 4.8.4 Minimum required: 4.3.1 gcc 4.8.4 WARNING: Conflicting installations: foam-extend settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.6 /bin/gzip tar 1.27.1 /bin/tar icoFoam WARNING: Conflicting installations: foam-extend settings : /home/cjjjoy/foam/foam-extend-3.2/applications/bin/linux64GccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. Is there anyone can help me with this? Thank you very much |
[foam-extend.org] core dumped for foam extended 3.2 on Ubuntu 16.04 | qjh888 | OpenFOAM Installation | 9 | September 27, 2016 17:39 |
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 | electrosin | OpenFOAM Installation | 40 | May 31, 2016 06:11 |
Openfoam 2.1 installation in ubuntu 12.04 | jsm | OpenFOAM Installation | 11 | May 7, 2012 05:56 |
openFOAM installation in ubuntu 11.10 | kirubhakaran | OpenFOAM Installation | 5 | February 17, 2012 03:16 |
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 09:33 |
