[OpenFOAM.org] blockMesh 'command not found' on Ubuntu 16.04 |
July 7, 2016, 07:39 |
Frederick
Dear all,
I am freshly new with OpenFOAM and I am going to use it for my PhD work. I recently installed it on Ubuntu 16.04 following the instructions from openfoamwiki website and just tried to run blockMesh. I faced the 'command not found' issue, so I checked online what could be the problem but I couldn't find a solution myself. I checked the log.make file but I can't find an error in it, maybe you will? The end of my bashrc is as following: Code:
alias of301='source $HOME/OpenFOAM/OpenFOAM-3.0.1/etc/bashrc WM_LABEL_SIZE=64' export PATH="$PATH:~$HOME/OpenFOAM/OpenFOAM-3.0.1/etc/bashrc" On the other hand, paraview is running fine from the bash. Many thanks for your help. Frederick |
July 10, 2016, 19:13 |
Joachim Herb
Rep Power: 22 |
Have you executed the command
of301 Code:
export PATH="$PATH:~$HOME/OpenFOAM/OpenFOAM-3.0.1/etc/bashrc" |
December 22, 2016, 03:31 |
Ashish Magar
Rep Power: 10 |
Currently, I am also encountering the same problem- blockMesh 'command not found'.
Previous to it was giving error "error while loading shared files." Then I added "source /home/magar/OpenFOAM/OpenFOAM-4.0/etc/" to ~/.bashrc. However it made the problem worse. |
December 22, 2016, 04:02 |
#4 | |
Rep Power: 16 |
When you mean it made the problem worse, what were the error messages? Cheers, Antimony |
December 22, 2016, 04:37 |
Ashish Magar
Rep Power: 10 |
Thank you Antimony for your quick reply...
Also I figured out I need to source the bashrc file " source ~/.bashrc " . I didnt do this step so I was getting error as "blockMesh: 'command not found'" Thanks again. |
December 22, 2016, 10:13 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
For future reference, this kind of issue is documented here: http://openfoamwiki.net/index.php/In...with_the_Shell
Workbench 18.2 Installation Error Ubuntu 16.04 | turbostudent | ANSYS | 1 | October 3, 2019 10:13 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
