[OpenFOAM.org] Building problem with Paraview 4.1.0 on Ubuntu 16.04
Old   June 16, 2016, 12:17
Default Building problem with Paraview 4.1.0 on Ubuntu 16.04
Nicolas Gallant
nigala is on a distinguished road
I have been trying to install OpenFoam 2.4.0 on Ubuntu 16.04 for quite a while and I didn't manage to make it work. I have been using this guide (2.5 Ubuntu 16.04):
https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04
Everything goes perfectly until step 9. If i call the paraFoam function, I get the error message:
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
./Allwclean
./Allwmake
If I call the paraview function, the 5.0.1 paraview pops up, but I still cannot open any OpenFoam file as the paraFoam function is not working properly.
I joined the log.makePV file as well as the terminal log during the installation.
Thanks in advance,
Nicolas
nigala is offline   Reply With Quote
Old   June 18, 2016, 18:03
Retired Super Moderator
Bruno Santos
Quick answer: Many thanks for the detailed logs!
The problem was this:
...:~/OpenFOAM$ sed -i -e 's=//#define GLX_GLXEXT_LEGACY=#define GLX_GLXEXT_LEGACY=' \
>   ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx
sed: can't read ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx: No such file or directory
...:~/OpenFOAM$ cd $WM_THIRD_PARTY_DIR/ParaView-4.1.0
The sed command failed, because you were in the wrong directory And I'm sorry about that, it's my fault. I failed to notice that I forgot to provide the missing step.
Please run the following commands:
./makeParaView4 -no-config -python -mpi -python-lib /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 > log.makePV 2>&1
This should solve the problem. Then continue from step 9.4.
Old   June 20, 2016, 11:18
Nicolas Gallant
Yesss!!!
It worked perfectly! Thanks a lot!
[OpenFOAM.org] Can't find installation instruction for Openfoam 2.4.x , on Ubuntu 16.04 titanium OpenFOAM Installation 14 February 20, 2020 12:46
[foam-extend.org] foam-extend 3.2 Paraview installation problem on Ubuntu 18.04 ordinary OpenFOAM Installation 3 September 1, 2018 23:01
[OpenFOAM.org] 4.0: Problems compiling ParaView on Ubuntu 16.04 RishabhG OpenFOAM Installation 1 September 18, 2016 16:55
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
ParaView 3.8.0 problem on debian Unseen OpenFOAM Installation 4 August 16, 2010 11:26
