[OpenFOAM.org] Current directory is not $WM_PROJECT_DIR
Old   June 8, 2016, 13:32
Exclamation Current directory is not $WM_PROJECT_DIR
Jack_Landis's Avatar
Jack_Landis is on a distinguished road
Dear all,
I'm trying to install OpenFOAM-2.2.1 from source on Ubuntu 15.10 (I have to use a code extension developed for that version of OpenFOAM). When I try to launch ./Allwmake I get this error:
./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
    The environment variables are inconsistent with the installation.
    Check the OpenFOAM entries in your dot-files and source them.
I know this question has already been answered but that answers didn't help me
Has someone any idea?
Thank you a lot!
Jacopo
Omnia per ipsum facta sunt,
et sine ipso factum est nihil,
quod factum est
Jack_Landis is offline   Reply With Quote
Old   June 8, 2016, 14:06
I solved the problem. I had to add a line to source the bashrc in the bashrc of Home and not in the one of OpenFOAM and then cancel the command end-of-file in the bashrc of OpenFOAM. Now it is compiling, I'm hoping it will be succesfull!
quod factum est
installation by sources, openfoam 2.1.1, problem, problems, source pack
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[OpenFOAM.org] Current directory is not $WM_PROJECT_DIR imani OpenFOAM Installation 17 September 6, 2020 09:19
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 20:09
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
