[OpenFOAM.org] OpenFOAM-3.0.1 installation problem in ubuntu-14.04.3
Old   May 25, 2016, 03:54
Default OpenFOAM-3.0.1 installation problem in ubuntu-14.04.3
Chun-Han Ko
Peter Ko is on a distinguished road
Hi there,
For some reasons,
I am doing the re-install of my OF-3.0.1 and I encounter the problems as follows...
root@Linux-PC:~/OpenFOAM# uname -m
x86_64
root@Linux-PC:~/OpenFOAM# source $HOME/OpenFOAM/OpenFOAM-3.0.1/etc/bashrc WM_LABEL_SIZE=64
bash: /opt/OpenFOAM-3.0.1/bin/foamEtcFile: No such file or directory
bash: /opt/OpenFOAM-3.0.1/bin/foamCleanPath: No such file or directory
bash: /opt/OpenFOAM-3.0.1/etc/config/settings.sh: No such file or directory
bash: /opt/OpenFOAM-3.0.1/etc/config/aliases.sh: No such file or directory
How should I do to solve this problems?? I need to create the folder "opt" myself??? or the package which I download was wrong?? I very sure that I do the some command as the "https://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-3.0.1/Ubuntu" told
best regards to every one,
Peter Ko
Peter Ko is offline   Reply With Quote
Old   May 21, 2017, 14:41
mehrdad
mehrdadzahir is on a distinguished road
i have this problem too!!! did you find the problem??? how can i overcome this problem?
mehrdadzahir is offline   Reply With Quote
Old   May 27, 2017, 08:54
Retired Super Moderator
Bruno Santos
Greetings to all!
There is a conflict of shell environments, namely another version/variant of OpenFOAM is already loaded in the shell environment and is leading the latest call to "etc/bashrc" getting confused as to where exactly the source code should be located.
@Peter Ko: My apologies, I only now noticed that you asked about this a year ago... it was around the time I was helping with things for OFW11 and I was not able to come by the forum.
Either way, all of this really depends on whether you two really want to install at "/opt" or a personal installation. Because:
  • If you want to really install at "/opt", then you need to define the environment variable "FOAM_INST_DIR" by using the following command:
    export FOAM_INST_DIR=/opt
    then run the sourcing command:
    source  /opt/OpenFOAM-3.0.1/etc/bashrc
  • If you want a personal installation, then get out of "root" mode and try the installation commands as a normal user.
Best regards,
Bruno
[OpenFOAM.org] OpenFOAM 3.0.1 in Ubuntu 18.04 jlr OpenFOAM Installation 4 January 3, 2019 13:57
[OpenFOAM.org] Problem during installation of openfoam 2.3.0 on ubuntu 16.04 jarvis OpenFOAM Installation 2 March 20, 2018 09:32
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[OpenFOAM.org] OpenFOAM 2.40 installation on Ubuntu 12.04 LTS eddykendo OpenFOAM Installation 1 July 18, 2015 18:38
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 05:56
