[foam-extend.org] Foam extend 3.2 wrong installation directory
Old   May 11, 2016, 06:52
Default Foam extend 3.2 wrong installation directory
geop is on a distinguished road
I'm trying to install Foam extend 3.2 by following this http://openfoamwiki.net/index.php/In...end-3.2/Ubuntu. I use Ubuntu 15.10. The problem is that when I run fe32, I get wrong installation path. I set "foamInstall=$HOME/$WM_PROJECT" but everytime I run fe32, I get "/opt/foam-extend-3.2/". I have no idea how "$FOAM_INST_DIR" is set to "/opt". Could you please direct me to where should I investigate?
Thank you
geop is offline   Reply With Quote
[foam-extend.org] Foam extend 3.2 installation issue Alewolves OpenFOAM Installation 1 March 25, 2017 16:01
udf error srihari FLUENT 1 October 31, 2016 15:18
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
