[foam-extend.org] Foam extend 3.1 rpmBuild error. |
May 9, 2016, 15:54 |
Saideep
Rep Power: 12 |
hi everyone;
I recently installed foam-extend-3.1 on Ubuntu-14.04 as specified in OpenWiki web-page. Copied is part of output upon compiling. I see some errors related to rpmBuild and have no clue how to overcome this error. Stage 3. Code:
This system rpm command: rpm --force-debian ======================================== Starting ThirdParty AllMake: Stage3 ======================================== Package name : metis-5.1.0 Package URL : http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/metis-5.1.0.tar.gz RPM spec file name: metis-5.1.0.spec Additional flags : Updating the ThirdParty environment variables before building package metis-5.1.0 RPM file name : /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/metis-5.1.0-linuxGccDPOpt.i386.rpm Package metis-5.1.0 is already installed Done installing package Package name : ParMGridGen-1.0 Package URL : http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/ParMGridGen-1.0.tar.gz RPM spec file name: ParMGridGen-1.0.spec Additional flags : Updating the ThirdParty environment variables before building package ParMGridGen-1.0 RPM file name : /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/ParMGridGen-1.0-linuxGccDPOpt.i386.rpm Package ParMGridGen-1.0 is already installed Done installing package Package name : libccmio-2.6.1 Package URL : http://portal.nersc.gov/svn/visit/tags/2.4.2/third_party/libccmio-2.6.1.tar.gz RPM spec file name: libccmio-2.6.1.spec Additional flags : Updating the ThirdParty environment variables before building package libccmio-2.6.1 RPM file name : /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/libccmio-2.6.1-linuxGccDPOpt.i386.rpm Download libccmio-2.6.1.tar.gz from : http://portal.nersc.gov/svn/visit/tags/2.4.2/third_party/libccmio-2.6.1.tar.gz --2016-05-09 19:24:23-- http://portal.nersc.gov/svn/visit/tags/2.4.2/third_party/libccmio-2.6.1.tar.gz Resolving portal.nersc.gov (portal.nersc.gov)... 128.55.6.160 Connecting to portal.nersc.gov (portal.nersc.gov)|128.55.6.160|:80... connected. HTTP request sent, awaiting response... 404 Not Found 2016-05-09 19:24:23 ERROR 404: Not Found. Making package libccmio-2.6.1 using RPM. Building package libccmio-2.6.1 using SPEC file : libccmio-2.6.1.spec. Optional args: error: File /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/SOURCES/libccmio-2.6.1.tar.gz: No such file or directory Installing package: libccmio-2.6.1 Uninstalling libccmio-2.6.1 using RPM: libccmio-2.6.1-linuxGccDPOpt.i386 Installing libccmio-2.6.1 using RPM file: /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/libccmio-2.6.1-linuxGccDPOpt.i386.rpm error: open of /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/libccmio-2.6.1-linuxGccDPOpt.i386.rpm failed: No such file or directory Done installing package Package name : mesquite-2.1.2 Package URL : http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/mesquite-2.1.2.tar.gz RPM spec file name: mesquite-2.1.2.spec Additional flags : Updating the ThirdParty environment variables before building package mesquite-2.1.2 RPM file name : /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/mesquite-2.1.2-linuxGccDPOpt.i386.rpm Package mesquite-2.1.2 is already installed Done installing package Package name : scotch-6.0.0 Package URL : http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/scotch-6.0.0.tar.gz RPM spec file name: scotch-6.0.0.spec Additional flags : Updating the ThirdParty environment variables before building package scotch-6.0.0 RPM file name : /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/scotch-6.0.0-linuxGccDPOpt.i386.rpm Package scotch-6.0.0 is already installed Done installing package Package name : parmetis-4.0.3 Package URL : http://glaros.dtc.umn.edu/gkhome/fetch/sw/parmetis/parmetis-4.0.3.tar.gz RPM spec file name: parmetis-4.0.3.spec Additional flags : Updating the ThirdParty environment variables before building package parmetis-4.0.3 RPM file name : /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/parmetis-4.0.3-linuxGccDPOpt.i386.rpm Package parmetis-4.0.3 is already installed Done installing package Package name : PyFoam-0.6.3 Package URL : http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/PyFoam-0.6.1.tar.gz RPM spec file name: PyFoam-0.6.3.spec Additional flags : Updating the ThirdParty environment variables before building package PyFoam-0.6.3 RPM file name : /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/PyFoam-0.6.3-linuxGccDPOpt.i386.rpm Making package PyFoam-0.6.3 using RPM. Building package PyFoam-0.6.3 using SPEC file : PyFoam-0.6.3.spec. Optional args: error: File /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/SOURCES/PyFoam-0.6.3-rc.tar.gz: No such file or directory Installing package: PyFoam-0.6.3 Uninstalling PyFoam-0.6.3 using RPM: PyFoam-0.6.3-linuxGccDPOpt.i386 Installing PyFoam-0.6.3 using RPM file: /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/PyFoam-0.6.3-linuxGccDPOpt.i386.rpm error: open of /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/PyFoam-0.6.3-linuxGccDPOpt.i386.rpm failed: No such file or directory Done installing package Package name : hwloc-1.7.2 Package URL : http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/hwloc-1.7.2.tar.gz RPM spec file name: hwloc-1.7.2.spec Additional flags : Updating the ThirdParty environment variables before building package hwloc-1.7.2 RPM file name : /home/saideep/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/i386/hwloc-1.7.2-linuxGccDPOpt.i386.rpm Package hwloc-1.7.2 is already installed Done installing package ======================================== Done ThirdParty AllMake: Stage3 ======================================== Code:
Making dependency list for source file interFoam1.C SOURCE=interFoam1.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-200 -I/home/saideep/foam/foam-extend-3.1/src/transportModels -I/home/saideep/foam/foam-extend-3.1/src/transportModels/incompressible/lnInclude -I/home/saideep/foam/foam-extend-3.1/src/transportModels/interfaceProperties/lnInclude -I/home/saideep/foam/foam-extend-3.1/src/turbulenceModels/incompressible/turbulenceModel -I/home/saideep/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/saideep/foam/foam-extend-3.1/src/foam/lnInclude -I/home/saideep/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/interFoam1.o In file included from interFoam1.C:69:0: /home/saideep/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPIMPLEControls.H: In function ‘int main(int, char**)’: /home/saideep/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPIMPLEControls.H:12:10: warning: unused variable ‘transonic’ [-Wunused-variable] bool transonic = ^ In file included from interFoam1.C:55:0: /home/saideep/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPIMPLEControls.H:3:9: warning: unused variable ‘nOuterCorr’ [-Wunused-variable] int nOuterCorr(readInt(pimple.lookup("nOuterCorrectors"))); ^ /home/saideep/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPIMPLEControls.H:4:9: warning: unused variable ‘nCorr’ [-Wunused-variable] int nCorr(readInt(pimple.lookup("nCorrectors"))); ^ /home/saideep/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPIMPLEControls.H:9:10: warning: unused variable ‘momentumPredictor’ [-Wunused-variable] bool momentumPredictor = ^ /home/saideep/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPIMPLEControls.H:12:10: warning: unused variable ‘transonic’ [-Wunused-variable] bool transonic = ^ g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-200 -I/home/saideep/foam/foam-extend-3.1/src/transportModels -I/home/saideep/foam/foam-extend-3.1/src/transportModels/incompressible/lnInclude -I/home/saideep/foam/foam-extend-3.1/src/transportModels/interfaceProperties/lnInclude -I/home/saideep/foam/foam-extend-3.1/src/turbulenceModels/incompressible/turbulenceModel -I/home/saideep/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/saideep/foam/foam-extend-3.1/src/foam/lnInclude -I/home/saideep/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/interFoam1.o -L/home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt \ -linterfaceProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -llduSolvers -lfoam -ldl -lm -o /home/saideep/foam/saideep-3.1/applications/bin/linuxGccDPOpt/interFoam1 /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_create' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_mutexattr_destroy' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlock_destroy' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlock_tryrdlock' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_mutex_trylock' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_mutexattr_init' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlock_rdlock' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_join' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlockattr_destroy' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlock_trywrlock' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_mutexattr_settype' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlockattr_init' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlock_init' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlock_unlock' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlock_wrlock' /home/saideep/foam/foam-extend-3.1/lib/linuxGccDPOpt/libfoam.so: undefined reference to `pthread_rwlockattr_setkind_np' collect2: error: ld returned 1 exit status make: *** [/home/saideep/foam/saideep-3.1/applications/bin/linuxGccDPOpt/interFoam1] Error 1 Thanks; Saideep |
May 12, 2016, 13:12 |
Saideep
Rep Power: 12 |
Anybody? Else is it only me with this problem?
I guess there is something I understood and compiled wrong for several times. Incase if anyone recognizes, the way i installed FE3.1 Ran the update and installations as specified for Ubuntu 14.04 in https://openfoamwiki.net/index.php/I...end-3.1/Ubuntu Later, From https://openfoamwiki.net/index.php/I...om_source_code Used git clone to get the version and compiled it. I use alias and OF versions 2.3/ 3.0 work fine. Only the FE31 has a problem. Any help much appreciated foamers. Saideep |
September 25, 2016, 20:34 |
Change the link for downloading the package
Thábata Maciel
Rep Power: 14 |
Hi, Saideep,
I recently had the same problem. I not sure why the link was not working for the download of libccmio-2.6.1.tar.gz during compiling of the Third Party packages. What I did was find another link that I could download it from, and replace it in the AllMake.stage3 file. I used this link: ftp://www.daba.lv/pub/TIS/bibliotekas/dazadas/libccmio-2.6.1.tar.gz However, please note that I am not sure this link is entirely trustworthy. It worked for me, but feel free to find another address to download it I hope I wasn't too late. |
foam extend 3.1, rpmbuild |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
