[foam-extend.org] error installing foam extend 1.6 in ubuntu 12.04
Old   May 8, 2016, 16:54
Default error installing foam extend 1.6 in ubuntu 12.04
larry
christos is on a distinguished road
I want to install OpenFOAM 1.6 extend in ubuntu 12.04.
I follow the steps from this site: https://openfoamwiki.net/index.php/I...u#Ubuntu_12.04
Here is what I do:
1. git clone git://git.code.sf.net/p/openfoam-extend/OpenFOAM-1.6-ext
2. cd OpenFOAM-1.6-ext
3. git checkout 1.6.1 -b 16ext
4. In order to make sure that no link is broken I manually download all the necessarry third party packages (scotch-5.1.10b.tar.gz, ParMGridGen-1.0.tar.gz, ParMetis-3.1.1.tar.gz, metis-5.0pre2.tar.gz, mesquite-2.1.2.tar.gz , libccmio-2.6.1.tar.gz) and copy-paste them to the OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES directory.
5. Then I proceed with the instructions given at the official extend repository
https://sourceforge.net/p/openfoam-e....04_64-bit.txt
Please find attached the log.AllMake.stage1 and log.AllMake.stage3. The error is on stage three and is connected with the libscotch library.
I have already searched the forum but nothing sed light on this.
Can someone give me a clear hind on how I can install foam ext. 1.6 in ubuntu 12.04.
Thanks, Chris
christos is offline   Reply With Quote
Old   May 9, 2016, 18:20
Default Hi guys
larry
Its me again
Is there anyone who has at least successfully installed foam ext. 1.6 in ubuntu 12.04 LTS 64bit and be eager to pinpoint me the installation instructions. I have successfully installed OpenFOAM 2.3.0 and OpenFOAM ext. 3.1. The reason that I want to install foam ext. 1.6 is because I have a centrifugal compressor simulation project that I need to finish and I want to deploy the solvers from foam ext. 1.6.
Thanks, Chris
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox manuc OpenFOAM Running, Solving & CFD 1 April 12, 2022 12:36
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 30, 2015 00:42
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
