[OpenFOAM.com] problems running in parallel on Mac OS X and Windows: only 1 cpu
Like Tree4Likes
Old   June 5, 2020, 17:27
I7aniel is on a distinguished road
Originally Posted by pgh View Post
Will be helpful, if you can post log of both serial and parallel run.
are you running the binaries in virtual box ? if yes, please check how many processor
and memory have you allocated to virtual box ?
Thanks for your reply!
I have 4096 mb ram in my Virtual Machine, unfortunatly i dont know what binaries are in my Virtualbox, I only changed Cores from 1 to 2 in my Virtualbox Menue.
I didnt lock the Solver, i printed it out in the terminal and saved a screenshot of the runtime :/ what i can say from the outwritten data, that it takes nearly constant 5 minutes for each second when running in parallel, when running normal on one core it takes at the start 3-5 min and later only 1 min for each second.
Edit: PAE is disabled in my Virtualbox, could that be the Problem?
Thank you for your help,
Kind Regards
Daniel
I7aniel is offline   Reply With Quote
[General] Running paraview parallel on windows 7 Naruto ParaView 3 April 22, 2017 08:12
Running parallel on Windows jaydeep OpenFOAM 2 December 6, 2016 16:31
Running Parallel on Windows using Python Scripts amarkkassery SU2 Installation 6 April 4, 2013 13:37
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
parallel computing problems with CPU time PAco FLUENT 2 December 16, 2005 13:37
