[OpenFOAM.org] Building OpenFOAM 3.0.1 on Ubuntu 16.04 - failed
Like Tree9Likes
Old   September 17, 2016, 12:56
Rishabh Golchha
RishabhG is on a distinguished road
I see. I did miss the dot. Thanks for pointing it out.
Now when I include it I get the error which i mentioned earlier
 cp: cannot stat '/home/rishabh/OpenFOAM/OpenFOAM-3.0.1/tutorials/incompressible/icoFoam/cavity/cavity': No such file or directory
Any idea what is the problem now
RishabhG is offline   Reply With Quote
Old   September 17, 2016, 20:00
Retired Super Moderator
Bruno Santos
Quick answer: The latest OpenFOAM User Guide is targeting OpenFOAM version 4. For OpenFOAM 3.0, you need to use this command instead:
cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity ./
For more details on the change from 3.0 to 4.0, see the first comment on this bug report: http://bugs.openfoam.org/view.php?id=2149#c6527
Old   November 25, 2016, 08:58
Default problem in installing openfoam 3.0.1 in ubuntu16.04
  #23
subhankar
SUBHANKAR is on a distinguished road
I couldn't understand the log.make file. It's showing error detected. Can anyone help me out here?
thanks and regards
Subhankar
SUBHANKAR is offline   Reply With Quote
Old   November 29, 2016, 17:06
Bruno Santos
Quick answer: The error message is this:
lnInclude/TensorI.H:705:26: internal compiler error: Segmentation fault
This either happened due to insufficient RAM or possibly due to a hardware issue.
If it was due to the lack of RAM, then please run the following commands:
free -h
lscpu
The first one will tell you how much RAM your machine has available and the second one will tell you how many cores the machine has got, e.g:
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    2
Core(s) per socket:    2
Socket(s):             1
NUMA node(s):          1
In this example, it has 4 cores.
It needs around 1 to 2 GB of RAM per core. If your machine only has 4GB of RAM, then you can only use 2 or 3 cores to build OpenFOAM.
Old   December 1, 2016, 04:11
subhankar
Hi wyldckat,
Thanks for replying...
My machine has 8GB RAM. So how can I solve the issue?
regards
Old   December 1, 2016, 20:21
Bruno Santos
You didn't answer my other questions...
Anyway, there are two possible solutions I can think of:
  1. Ignore the build error and run the Allwmake command one again, in hope that the next attempt will work as intended.
  2. From the log file, I can see this: "linux64GccDPInt64Opt" - which means that you are building with 64-bit labels. If you only have 8GB of RAM, you should not be using the "WM_LABEL_SIZE=64" option, unless you have access to some other machine that has 512GB of RAM or way more than that.
Old   December 2, 2016, 05:11
subhankar
Hi bruno,
my system has
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
CPU(s): 4
Socket(s): 1
NUMA node(s): 1
CPU family: 6
I followed the wiki page completely and as per the instructions only i followed the commands.
regards
subhankar
Old   December 2, 2016, 07:14
Bruno Santos
Quick answer: OK, your machine have 2 real cores and 2 threads per core... if you are following the instructions given here: http://openfoamwiki.net/index.php/In...u#Ubuntu_16.04 - then please try running with only 3 threads, like this:
./Allwmake -j 3 > log.make 2>&1
Hopefully the compiler will be able to build properly past the problematic location, by having a few more free resources.
Old   December 6, 2016, 01:43
subhankar
Hi Bruno,
I tried to do everything fresh again from the start including the changes you said.The log.makePV file is showing segmentation fault.
regards
Old   December 22, 2016, 14:31
Bruno Santos
Sorry for the late reply. Something really strange is going on in your machine. I strongly suggest you do some system check ups, for example as instructed here: https://openfoamwiki.net/index.php/H...and_CPU_are_OK
Old   February 2, 2017, 10:24
Chia
chia87 is on a distinguished road
Hi everyone,
I followed https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04 , for installation of OpenFoam on Ubuntu 16.04
I failed at step 10
For building ParaView with Python and MPI, it depends on whether you have installed the i686 or x86_64 architecture of Ubuntu. To check this, run:
uname -m
#note, im running on x86_64
For x86_64:
#this will take a while... somewhere between 30 minutes to 2 hours or more
./makeParaView4 -python -mpi -python-lib /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 > log.makePV 2>&1
I failed here,
when i entered the command ' ./makeParaView4 -python -mpi -python-lib /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 > log.makePV 2>&1 '
my entire screen froze and log me out of ubuntu
Anyone has any idea , any input much appreciated
EDIT: I adjusted the amount of allocated memory, and it seems to solve the problem
chia87 is offline   Reply With Quote
3.0.1, xenial xerus
[OpenFOAM.org] OpenFOAM 3.0.1 in Ubuntu 18.04 jlr OpenFOAM Installation 4 January 3, 2019 13:57
[OpenFOAM.org] OpenFOAM 5 source pack installation on Ubuntu 16.04 CjjJoy OpenFOAM Installation 23 June 6, 2018 11:55
[OpenFOAM.com] Installation of OpenFOAM 1.7.1 on Ubuntu 16.04 MM_Khan OpenFOAM Installation 11 September 3, 2017 10:22
[OpenFOAM.com] Problems building OF-1.7.x version, Ubuntu 16.04, Gcc-5.4.0 wadekar OpenFOAM Installation 2 February 22, 2017 12:11
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
