[OpenFOAM.org] OpenFoam installation on CentOs 6.5 without root access |
June 10, 2016, 03:19 |
#21 | ||
Wang Wei
Rep Power: 10 |
Hi,Chariton, below is the commands I used in compiling openfoam v3.0.1 in my /home directory.
January 31, 2018, 05:08 |
#22 | |
Chayanit Nigaltia
Rep Power: 8 |
[chayanit@un03 OpenFOAM]$ tar -xzf OpenFOAM-2.3.0.tgz gzip: stdin: not in gzip format tar: Child returned status 1 tar: Error is not recoverable: exiting now |
December 10, 2018, 06:00 |
#23 |
Ramana
Rep Power: 9 |
Hi everyone, I'm also trying to install OF5.0 on my institute cluster in home folder. I also don't have root access. I have followed all the instruction given in this link, https://openfoam.org/download/5-0-source/. After running ./Allwake command I'm getting following error
In file included from UOPwrite.C:30:0: PstreamGlobals.H:42:17: fatal error: mpi.h: No such file or directory #include <mpi.h> ^ compilation terminated. make: *** [/data/me16d023/OpenFOAM/OpenFOAM-5.0/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/Pstream/mpi/UOPwrite.o] Error 1 Anybody have solution ? Please help me. |
December 16, 2018, 15:18 |
#24 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: The Institute cluster should have a way to load/activate the MPI version that could be used with OpenFOAM. My guess is that if you run the following command:
module avail Code:
module load openmpi/1.10.1
December 21, 2018, 11:09 |
#25 |
Ramana
Rep Power: 9 |
Thank you sir. It work for me.
September 11, 2019, 05:26 |
#26 |
Fahime Firoozpour
Rep Power: 8 |
July 1, 2020, 14:00 |
#27 | ||||||
James
Rep Power: 12 |
Hi Bruno, I followed your instructions to install OF3.0.1 on the cluster without root access given in this link. https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL SInce the OS of my university cluster is CentOS Linux release 7.8.2003 (Core). I followed the post#3 i.e for CentOS 7.1 I skipped step 1, 2 and 3. Step 4, 5, 6, 7 worked normally. For step 8, I first loaded Quote:
Then I proceeded to compile further. I didn't have any error or warning. However. the final compilation with ./Allwmake failed. The first error says Quote:
Would you please have a look at the log file of the compilation I have attached. I would sincerely appreciate your help. Best regards, James Last edited by Madeinspace; July 1, 2020 at 19:35. |
March 6, 2021, 08:48 |
#28 |
FBR
I need to install openfoam6 on a cluster without root access. Is there any useful website to guide me? Thanks |
March 6, 2021, 11:31 |
#29 | |
Mark Olesen
Rep Power: 40 |
Take a look at the wiki: https://develop.openfoam.com/Develop...wikis/building Should be reasonably similar to what you need for the .org version. |
centos, installation of openfoam, root access |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
[OpenFOAM.org] OpenFOAM 2.4.x on CentOS 6.5 | kpsl | OpenFOAM Installation | 2 | July 27, 2015 06:50 |
[OpenFOAM.org] How to get OpenFoam compiled on a cluster with CentOS 6.5 and no root permissions | hulli | OpenFOAM Installation | 2 | November 6, 2014 18:01 |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 7 | July 30, 2009 03:14 |
OpenFOAM 15 and CentOS 52 installation issues | remrich | OpenFOAM Bugs | 9 | March 20, 2009 01:48 |
