[OpenFOAM.org] OpenFOAM 3.0 install incomplete with Deb package on Ubuntu
Old   February 27, 2016, 08:00
Default OpenFOAM 3.0 install incomplete with Deb package on Ubuntu
chanakya yadav
chanakya is on a distinguished road
I followed installation process. I did not get any error. A folder named opt is created with openfoam30 and paraviewopenfoam44. But when I use code
icoFoam -help
it is showing that icoFoam is not a command. I used the user configuration process first two steps exactly. with a dot for bashrc.
chanakya is offline   Reply With Quote
Old   February 27, 2016, 10:48
Retired Super Moderator
Bruno Santos
Quick answer: I guess you followed the instructions given here: http://www.openfoam.org/download/ubuntu.php
In the section "User Configuration" is explained in detail how to source the script that loads up the OpenFOAM environment.
Nonetheless, please run the following command, so that we can diagnose the problem:
grep "bashrc" ~/.bashrc
Old   February 27, 2016, 23:44
Default wyldckat, I have tried your code line.
chanakya yadav
source# ~/.bashrc: executed by bash(1) for non-login shells.
#source /opt/openfoam30/etc/bashrc
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
. opt/openfoam30/etc/bashrc
I got this in the terminal. thank you for quick response.
chanakya@chanakya-Inspiron-3542:~$ sudo apt-get install openfoam30
Reading package lists... Done
Building dependency tree
Reading state information... Done
openfoam30 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
chanakya@chanakya-Inspiron-3542:~$ sudo apt-get install paraviewopenfoam44
paraviewopenfoam44 is already the newest version.
Last edited by wyldckat; March 6, 2016 at 12:40. Reason: Added [CODE][/CODE] markers
Old   March 6, 2016, 12:42
Bruno Santos
Originally Posted by chanakya View Post
Quick answer:
  1. You need to edit the file "~/.bashrc" with a text editor.
  2. Search for this line:
  3. There is a slash character "/" missing before the "opt" name. What I mean is that you need to change that line for this line:
    . /opt/openfoam30/etc/bashrc
  4. Save and close the file, within the text editor.
  5. Start a new terminal window or tab and it should now work as intended.
[swak4Foam] how does install swak4foam with OpenFOAM 3.0? milad653279 OpenFOAM Community Contributions 24 December 29, 2015 08:49
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
