February 26, 2016, 06:56 |
Paraview with MPI Support
London (United Kingdom)
Rep Power: 11 |
Hi i dont know if this is the right place for help with OpenFoam-Ext, however here's hoping.
I have successfully build OpenFoam Ext 3.2, including the Third Party applications. I tried running Paraview in parallel using the command mpirun -env I_MPI_DEBUG 5 -ppn 8 -n 16 -hosts node0,node1 -env I_MPI_FABRICS=shm:dapl -env I_MPI_DAPL_PROVIDER=ofa-v2-ib0 -env I_M PI_DYNAMIC_CONNECTION=0 pvserver -display :0.0 However, i get the following output from my torque job that i use to submit the above Connection URL: cs://node0:11111 Exiting... Waiting for client... Connection URL: cs://node0:11111 Exiting... ........... (slightly cut down, but 1 instance succeeds on each node, all other instances fail) So after a bit of research i find i need to explicitly enable MPI support. I hope i affected the correct files, i found two spec files that related to Paraview ParaView-4.3.1_Server.spec ParaView-4.3.1.spec in both files i have set _withMPI to true %{!?_withMPI: %define _withMPI true} and rebuild paraview (after running ./Allclean.stage4) I still have the same problem where multiple instances of paraview are started but only one succeeds. (tbh i barely know what im doing in this space, its not my area of expertise, and the client seem unable to build it themselves.) Have i affected the right file? pvserver -V returns paraview version 4.3.1 Is there any other files i need to affect? Thanks in advance |
February 29, 2016, 05:33 |
Rep Power: 11 |
Can anyone help with this? im at a loss..
If you need more information please let me know, if there is anywhere better suited to asking this question that information would also be useful thanks |
OpenFOAM extended 4.0 Error with Multinode Set-up | Liweix | OpenFOAM Running, Solving & CFD | 1 | February 18, 2020 01:50 |
[General] Paraview Python Support | FlyBob91 | ParaView | 2 | January 24, 2018 22:47 |
[General] "OpenGL support inadequate" error with Paraview 5.2 binaries | Ramsky | ParaView | 0 | December 19, 2016 02:57 |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 13:36 |
[OpenFOAM] Paraview client/server does not work with ParaView 5.0.1 | snak | ParaView | 0 | October 17, 2016 11:22 |
