Problem with installing OpenFOAM 2.0.X
Old   February 3, 2016, 12:03
Lightbulb Problem with installing OpenFOAM 2.0.X
Mohsen
mohsen.boojari is on a distinguished road
hi everyone
can any one translate this command for me? i want to know what does exactly this command do ! I have a problem with this and i want to know whether i can do it manually or not . thank you all !
sed -i s/"cmake-2.8.3"/"cmake-2.8.5"/g $WM_THIRD_PARTY_DIR/makeCmake
sed -i s/"cmake-2.8.4"/"cmake-2.8.5"/g $HOME/OpenFOAM/OpenFOAM-2.0.x/etc/config/myParaview.sh
and here is My terminal error :
sed: can't read /makeCmake: No such file or directory
mohsen.boojari is offline   Reply With Quote
Old   February 3, 2016, 12:17
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Answering your question: command replaces all occurrences of "cmake-2.8.3" to "cmake-2.8.4". (https://duckduckgo.com/?q=what+is+sed%3F, first link, then section Usage: https://en.wikipedia.org/wiki/Sed#Substitution_command).
And since the error is
It means $WM_THIRD_PARTY_DIR environment variable expands into empty string, i.e. it is not defined. So, I guess, you have forgotten to set up environment variables with "source /path/to/your/OpenFOAM/OpenFOAM-2.0.x/etc/bashrc".
alexeym is offline   Reply With Quote
Old   February 3, 2016, 12:27
Mohsen
Originally Posted by alexeym View Post
first of all thanks for your quick and useful reply.
about environment variables i use these commands, are they wrong?
echo "alias OF20x='source \$HOME/OpenFOAM/OpenFOAM-2.0.x/etc/myBashrc'" >> $HOME/.bashrc
cp $HOME/OpenFOAM/OpenFOAM-2.0.x/etc/bashrc $HOME/OpenFOAM/OpenFOAM-2.0.x/etc/myBashrc
sed -i s/"paraview.sh"/"myParaview.sh"/g $HOME/OpenFOAM/OpenFOAM-2.0.x/etc/myBashrc
cp $HOME/OpenFOAM/OpenFOAM-2.0.x/etc/config/paraview.sh $HOME/OpenFOAM/OpenFOAM-2.0.x/etc/config/myParaview.sh
Old   February 3, 2016, 12:41
Alexey Matveichev
Surely it is fun to use duckduckgo.com, yet you can use your preferred search engine (especially before posting questions):
https://duckduckgo.com/?q=how+to+set...or+openfoam%3F
1st link: http://www.openfoam.org/download/source.php (section Setting Environment Variables, instead of 3.0.1 you can put 2.0.x)
5th link: https://openfoamwiki.net/index.php/I...ment_Variables
openfoam 2.0.x, paraview, sed
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
[OpenFOAM.com] Problem installing OpenFoam 1.5 on Ubuntu 12.04???? tareqkh OpenFOAM Installation 5 July 19, 2015 16:10
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 14:24
Problem on installing Openfoam on 64bit sgi station gregjunqua OpenFOAM Installation 4 October 12, 2011 17:28
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 05:36
