[foam-extend.org] /lib64/libc.so.6: version `GLIBC_2.14' not found |
January 28, 2016, 12:59 |
Sangeetha
I am trying to compile swak4foam on the HPC cluster and I get the below error:
/opt/build/BUILD/foam-extend-3.1/wmake/bin/linux64Gcc/wmkdep: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/build/BUILD/foam-extend-3.1/wmake/bin/linux64Gcc/wmkdep) I see this error even after loading gcc 5.1.0. Why does it look for the library only in /usr/lib64? Is there any way to change this default behavior? |
glibc2.14, swak4foam |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
missing vtf3.h BPatch.h papi.h | linch | OpenFOAM Installation | 41 | July 24, 2012 14:45 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
