[OpenFOAM.com] 3.0+ on Windows ---- How do I run tutorials?
Like Tree8Likes
Old   September 7, 2017, 07:58
pgh
Pawan Ghildiyal
pgh is on a distinguished road
Well i have not use this one but it should be pretty same . Better copy your tutorial in /mtn/c/users/lenzo assuming your user name is lenzo and then run it . You can browse this location directly from windows browser as well
pgh is offline   Reply With Quote
Old   September 14, 2017, 11:02
Lenzo
lenzo is on a distinguished road
Dear pgh,
are you sure it works in that way? I think that the most probably way to connect the virtual machine and my computer should be through a special program. But still i can't figure out which one is.
Anyone has any other suggestion?
lenzo is offline   Reply With Quote
Old   November 14, 2017, 13:30
Ed O'Malley
edomalley1 is on a distinguished road
Originally Posted by pgh View Post
Hi
This path "/opt/OpenFOAM/OpenFOAM-v1606+/tutorials" can only be accessed via
command line from shell of container . If you want to locate in your c drive , you need
to copy this in your c drive .
Do following from your container's bash shell
cd workingDir
cp -ar $FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity .
It will copy the cavity tutorial inside c\user\francis . assuming francis is your
user name
Edit - nevermind - I figured it out.
Thanks - this worked for me. Stupid question - after I modify the files and save them back on my c drive, how do I copy them back into the workingDir? Thanks!
lenzo likes this.
Last edited by edomalley1; November 14, 2017 at 13:57. Reason: answered my own question.
edomalley1 is offline   Reply With Quote
Old   January 15, 2018, 04:33
Lenzo
Any idea how to copy a new case into the workingDir of openfoam in WINDOWS?
Because I work in an ubuntu, but sometimes in a windows. So, how Can i copy the changes into the workingDir of windows?
Thank you!
Originally Posted by lenzo View Post
Dear pgh,
Old   January 15, 2018, 05:22
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
The working directory is
c:\OpenFoam\16.10\<username>\run from windows
/cygdrive/c/OpenFoam/16.10/<username>/run form the shell
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   October 22, 2018, 10:52
Klaas Albers
Mr.Tea is on a distinguished road
I have the same Problem with the Tutorial files.
cd workingDir
cd cavity
blockMesh
icoFoam
When i try this command only the first one works. When i try the second one it displays this message:
cp: missing destination file operand after '/opt/OpenFOAM/OpenFOAM-v1806/tutorials/incompressible/icoFoam/cavity/cavity'
Try 'cp --help' for more information.
[ofuser@default workingDir]$
I hope you guys can help me.
Kind Regards, Klaas
Mr.Tea is offline   Reply With Quote
Old   October 24, 2018, 18:50
Retired Super Moderator
Bruno Santos
Quick answer: If it states:
cp: missing destination file operand after ...
it means that you missed the final dot in the command that you indicated:
It's cavity space dot at the end of the command
How to run other tutorials included in OpenFOAM? BhaluBear OpenFOAM Running, Solving & CFD 8 May 21, 2016 11:19
How to run the tutorials' problems? ranasa OpenFOAM Running, Solving & CFD 2 July 24, 2014 16:10
How to run su2 on windows and use multicore hedley SU2 1 June 24, 2014 21:44
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Help, can't stop solver run...Windows OS ben akih CFX 2 November 13, 2006 11:05
