[Other] ParaFoam/ParaView Mesa 11.0.4
Old   December 18, 2015, 08:32
Default ParaFoam/ParaView Mesa 11.0.4
Chrishas is on a distinguished road
Hi all,
I'm trying to compile Paraview 4 from the Third Party package using the following command:
./makeParaView4 VTK_OPENGL_HAS_OSMESA=ON VTK_USE_X=OFF PARAVIEW_BUILD_QT_GUI=ON OSMESA_LIBRARY=/usr/local/mesa/gallium/11.0.4/lib/libOSMesa.so OSMESA_INCLUDE_DIR=/usr/local/mesa/gallium/11.0.4/include OPENGL_INCLUDE_DIR=/usr/local/mesa/gallium/11.0.4/include OPENGL_gl_LIBRARY=/usr/local/mesa/gallium/11.0.4/lib/libOSMesa.so OPENGL_glu_LIBRARY=/usr/local/glu/9.0.0/lib/libGLU.so
This results in the following error:
[ 48%] Linking CXX shared library ../../../lib/libvtkGUISupportQt-pv4.4.so
[ 48%] Building CXX object VTK/Rendering/LIC/CMakeFiles/vtkRenderingLIC.dir/vtkLineIntegralConvolution2D.cxx.o
Building CXX object VTK/Filters/ParallelMPI/CMakeFiles/vtkFiltersParallelMPI.dir/vtkPExtractGrid.cxx.o
[ 48%] Building CXX object VTK/IO/Parallel/CMakeFiles/vtkIOParallel.dir/vtkMultiBlockPLOT3DReader.cxx.o
CMakeFiles/vtkGUISupportQt.dir/QVTKWidget.cxx.o: In function `QVTKWidget::x11_setup_window()':
QVTKWidget.cxx:(.text+0x985): undefined reference to `vtkXOpenGLRenderWindow::GetDisplayId()'
QVTKWidget.cxx:(.text+0xa22): undefined reference to `XGetWindowAttributes'
QVTKWidget.cxx:(.text+0xa62): undefined reference to `XCreateWindow'
QVTKWidget.cxx:(.text+0xa90): undefined reference to `XGetWMColormapWindows'
QVTKWidget.cxx:(.text+0xaef): undefined reference to `XFree'
QVTKWidget.cxx:(.text+0xb80): undefined reference to `XSetWMColormapWindows'
QVTKWidget.cxx:(.text+0xb90): undefined reference to `XFree'
QVTKWidget.cxx:(.text+0xb98): undefined reference to `XFlush'
CMakeFiles/vtkGUISupportQt.dir/QVTKWidget.cxx.o: In function `vtkXOpenGLRenderWindow::GetGenericDisplayId()':
QVTKWidget.cxx:(.text._ZN22vtkXOpenGLRenderWindow19GetGenericDisplayIdEv[_ZN22vtkXOpenGLRenderWindow19GetGenericDisplayIdEv]+0x1): undefined reference to `vtkXOpenGLRenderWindow::GetDisplayId()'
collect2: error: ld returned 1 exit status
make[2]: *** [lib/libvtkGUISupportQt-pv4.4.so.1] Error 1
make[1]: *** [VTK/GUISupport/Qt/CMakeFiles/vtkGUISupportQt.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
Everything is compiled using gcc 5.2.0 and Python 2.7.10.
In the Paraview with Mesa/llvmpipe page the flag --disable-shared-glapi is used for Mesa but for 11.0.4 it needs to be enabled. Also the PARAVIEW_BUILD_QT_GUI is OFF in that same page but no paraview gui is compiled at all?
Thanks,
Chris
Chrishas is offline   Reply With Quote
Old   December 19, 2015, 14:17
Retired Super Moderator
Bruno Santos
Quick question: Which Linux Distribution are you using?
I ask this because it will make it easier for me to reproduce the same problem.
In addition, how did you install Mesa?
In the meantime, maybe this can help: http://www.openfoam.org/mantisbt/view.php?id=793
Old   December 21, 2015, 06:02
Thanks for the reply.
The distro is Scientific Linux 6.6 and mesa was compiled using the following configure command:
./configure --prefix=/usr/local/mesa/gallium/11.0.4 CXXFLAGS="-O2 -g -DDEFAULT_SOFTWARE_DEPTH_BITS=31"     CFLAGS="-O2 -g -DDEFAULT_SOFTWARE_DEPTH_BITS=31"     --disable-xvmc     --disable-glx     --disable-dri     --with-dri-drivers=""     --with-gallium-drivers="swrast"     --enable-texture-float     --enable-shared-glapi     --disable-egl     --with-egl-platforms=""     --enable-gallium-osmesa     --enable-gallium-llvm=yes     --enable-llvm-shared-libs
I will try the files in the bug report as well.
[OpenFOAM] Problem with apply button in paraFoam/paraView mukut ParaView 2 December 7, 2014 07:53
Installing OpenFoam on windows 7-64 Dadou OpenFOAM Installation 10 February 11, 2014 17:20
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
Start cfx5pre and cfd5post with -gr mesa Lance CFX 5 January 26, 2010 04:18
[OpenFOAM] symbol lookup error paraFoam/paraview OFU ParaView 1 August 5, 2009 06:11
