[OpenFOAM.org] PARAView4 installation problems
Old   December 10, 2015, 10:10
Default PARAView4 installation problems
RC
recif is on a distinguished road
I am trying to install OpenFOAM-3.0.x from the git repo in Ubunto 14.
The OpenFOAM installation seemed to proceed fine, but when I ran makeParaview4, I got the error:
[ 95%] Generating Documentation HTMLs from xmls
xmlpatterns: could not exec '/usr/lib/x86_64-linux-gnu/qt5/bin/xmlpatterns': No such file or directory
Processing wiki sources
Processing wiki filters
Processing wiki writers
Processing wiki readers
[ 95%] Compiling Qt help project NonOrthogonalSource.qhp
qhelpgenerator: could not exec '/usr/lib/x86_64-linux-gnu/qt5/bin/qhelpgenerator': No such file or directory
Plugins/NonOrthogonalSource/CMakeFiles/NonOrthogonalSource.dir/build.make:89: recipe for target 'Plugins/NonOrthogonalSource/doc/NonOrthogonalSource.qch' failed
make[2]: *** [Plugins/NonOrthogonalSource/doc/NonOrthogonalSource.qch] Error 1
CMakeFiles/Makefile2:16509: recipe for target 'Plugins/NonOrthogonalSource/CMakeFiles/NonOrthogonalSource.dir/all' failed
make[1]: *** [Plugins/NonOrthogonalSource/CMakeFiles/NonOrthogonalSource.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
make: *** [all] Error 2
Installation complete for paraview-4.4.0
Set environment variables:
export ParaView_DIR=/home/rc/OpenFOAM/ThirdParty-3.0.x/platforms/linux64Gcc/ParaView-4.4.0
export PATH=$ParaView_DIR/bin:$PATH
export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.4
Done
I have xmlpatterns and qhelpgenerator in /usr/bin. Is there a way to change where they are searched for, or should I create a soft link to /usr/lib/x86_64-linux-gnu/qt5/bin/qhelpgenerator, etc?
A perhaps unrelated problem is that I was able to run blockMesh and icoFoam in the cavity examples subdirectory, but when I tried to run paraFoam I get the error:
paraFoam
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
./Allwclean
./Allwmake
However, on doing this I get the error:
./Allwclean
+ wclean libso vtkPV4Readers
wclean vtkPV4Readers
/home/rc/OpenFOAM/OpenFOAM-3.0.x/applications/utilities/postProcessing/graphics/PV4Readers/vtkPV4Readers
+ PV4blockMeshReader/Allwclean
+ rm -f /home/rc/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/lib/libPV4blockMeshReader*
+ rm -rf PV4blockMeshReader/Make
+ wclean libso vtkPV4blockMesh
wclean vtkPV4blockMesh
/home/rc/OpenFOAM/OpenFOAM-3.0.x/applications/utilities/postProcessing/graphics/PV4Readers/PV4blockMeshReader/vtkPV4blockMesh
+ PV4FoamReader/Allwclean
+ rm -f /home/rc/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/lib/libPV4FoamReader*
+ rm -rf PV4FoamReader/Make
+ wclean libso vtkPV4Foam
wclean vtkPV4Foam
/home/rc/OpenFOAM/OpenFOAM-3.0.x/applications/utilities/postProcessing/graphics/PV4Readers/PV4FoamReader/vtkPV4Foam
[08:55 AM][rc@rc-System-Product-Name] [~/OpenFOAM/OpenFOAM-3.0.x/applications/utilities/postProcessing/graphics/PV4Readers]
518:18 $ ./Allwmake
ERROR: ParaView not found in /home/rc/OpenFOAM/ThirdParty-3.0.x/platforms/linux64Gcc/ParaView-4.4.0
[08:56 AM][rc@rc-System-Product-Name] [~/OpenFOAM/OpenFOAM-3.0.x/applications/utilities/postProcessing/graphics/PV4Readers]
I would appreciate any suggestions to resolve these problems.
recif is offline   Reply With Quote
Old   December 12, 2015, 16:13
Retired Super Moderator
Bruno Santos
Quick answer: Detailed instructions are available here: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04
The problem you're seeing is that Qt5 is being used by default. In step #9 you will see the fix for the problem:
export QT_SELECT=qt4
Old   December 12, 2015, 21:04
RC
Thanks. I thought I was following the instructions on the wiki earlier, but I may have been looking at those for a different version of openFOAM.
openfoam, paraview
[OpenFOAM.com] v1606+ Problems of installation on iMac Intercooled OpenFOAM Installation 4 November 15, 2016 21:22
[Other] Installation problems with OpenFOAM 2.3.x for Windows from cfdsupport.com Nkl OpenFOAM Installation 7 March 31, 2015 11:59
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
Problems with installation batta31 OpenFOAM Installation 2 September 4, 2012 08:01
installation problems on upgrade from win 3.26 to mic Siemens 5 June 20, 2007 10:40
