[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on CentOS-6.6-x86-64
Like Tree3Likes
Old   November 28, 2015, 14:58
Milan
Milan2013 is on a distinguished road
Thanks
I just did. Everything seems to be fine now?
Milan2013 is offline   Reply With Quote
Old   November 28, 2015, 15:18
Retired Super Moderator
Bruno Santos
Finally! At least ParaView is now built and installed with success!
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
wmSET $FOAM_SETTINGS
which paraview
./Allwclean
./Allwmake
"which paraview" should tell you the right place where it's installed.
And Allwmake should now work as intended!
Old   November 28, 2015, 15:56
Milan
Thanks, Bruno. From what I see, it did. I attached the command line output text, everything seems fine 100%
wyldckat likes this.
Old   November 28, 2015, 16:02
Bruno Santos
Yes! Finally!! It seems like everything is finally working as intended!
If in post #13 I wasn't in such a hurry, I perhaps might have noticed that this:
rm -r platforms/linux64Gcc48/ParaView-4.1.0/
would fail to work properly if "ParaView-4.1.0" was a file and not a folder. The slash at the end explicitly looks for a folder named "ParaView-4.1.0" and not a file .
This is one of several reasons why OpenFOAM is so picky about every single detail, given that GNU/Linux is also very picky about these kinds of details
Old   November 28, 2015, 16:05
Milan
Yes, I noticed that at the time...thought you did too :P
Sorry for disturbing your time. Thanks for the support, I appreciate it!!!
Milan
centos 6.6
[OpenFOAM.org] Problems installing OpenFOAM 2.3.1 in Ubuntu 12.04 masoudshao OpenFOAM Installation 10 August 9, 2018 07:13
[OpenFOAM.org] Installing OpenFOAM 2.4.0 on CentOS 6.6 kyrox OpenFOAM Installation 21 May 30, 2016 19:49
Installing OpenFOAM 2.1.1 on CentOS 5.x phuchuynh OpenFOAM Installation 1 October 10, 2012 17:58
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 20:09
