[foam-extend.org] foam-extent 3.1 - OpenSUSE 13.2
Old   November 5, 2015, 06:21
Default foam-extent 3.1 - OpenSUSE 13.2
aylalisa is on a distinguished road
I've started to install foam-extent 3.1 on OpenSUSE 13.2 following
https://openfoamwiki.net/index.php/I...om_source_code
The rpm built of paraview stops with this error:
Linking CXX shared library ../../../lib/libvtkRenderingVolume-pv4.0.so
[ 61%] Built target vtkRenderingVolume
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
error: Bad exit status from /home/../foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.fQKgrp (%build)
How can I solve the problem?
Ayla
aylalisa is offline   Reply With Quote
Old   November 7, 2015, 16:04
Retired Super Moderator
Bruno Santos
Quick answer: Check if this thread helps you: http://www.cfd-online.com/Forums/ope...end-3-1-a.html
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
