[OpenFOAM.org] wmake problem
Old   October 7, 2015, 04:31
Default wmake problem
vville is on a distinguished road
I tried to modify the forces.C a bit, to ease the post processing. Then, when trying to wmake it, I get
+ wmake libso cloud
./Allwmake: 6: ./Allwmake: wmake: not found
+ wmake libso field
./Allwmake: 7: ./Allwmake: wmake: not found
+ wmake libso forces
./Allwmake: 8: ./Allwmake: wmake: not found
+ wmake libso fvTools
./Allwmake: 9: ./Allwmake: wmake: not found
+ wmake libso IO
./Allwmake: 10: ./Allwmake: wmake: not found
+ wmake libso jobControl
./Allwmake: 11: ./Allwmake: wmake: not found
+ wmake libso systemCall
./Allwmake: 12: ./Allwmake: wmake: not found
+ wmake libso utilities
./Allwmake: 13: ./Allwmake: wmake: not found
after running Allwmake from /openfoam240/src/postProcessing/functionObjects. which make gives
/usr/bin/make
and for wmake
/opt/openfoam240/wmake/wmake
Any ideas what I'm doing wrong?
vville is offline   Reply With Quote
Old   October 8, 2015, 06:01
Joachim Herb
jherb is on a distinguished road
Did you call
source $HOME/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc
What is the output of
which wmake
jherb is offline   Reply With Quote
Mesh& steptime independant: conduction-convection problem Fati1 Main CFD Forum 1 October 28, 2018 14:52
wmake problem: "sudo: wmake: command not found" Luiggito OpenFOAM Programming & Development 1 January 11, 2015 14:48
code compilation problem with wmake bmikuz OpenFOAM Programming & Development 2 October 17, 2012 10:30
OpenFOAM installation problem. File missing in wmake shangzung OpenFOAM Installation 1 July 8, 2010 11:57
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
