[OpenFOAM.org] Error for PV4blockMeshReader PV4FoamReader installation |
August 22, 2015, 16:30 |
anton
Rep Power: 11 |
After running OpenFOAM/OpenFOAM-2.4.x/applications/utilities/postProcessing/graphics/PV4Readers# ./Allwmake I get this error message:
ERROR: ParaView not found in /usr/local/OpenFOAM/ThirdParty-2.4.x/platforms/linux64Gcc/ParaView-4.1.0 Please advise. Thanks |
August 22, 2015, 16:54 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: ParaView is not built yet. Continue to follow the installation instructions you're following (you could have stated which ones you're following ), because you should see next the instructions for building ParaView.
August 22, 2015, 17:32 |
anton
Rep Power: 11 |
Thank you,
I did not pay attention to paraView compiling errors. make[1]: *** [VTK/Rendering/OpenGL/CMakeFiles/vtkRenderingOpenGL.dir/all] Error 2 Makefile:117: recipe for target 'all' failed make: *** [all] Error 2 --- Installation complete for paraview-4.1.0 Set environment variables: export ParaView_DIR=/usr/local/OpenFOAM/ThirdParty-2.4.x/platforms/linux64Gcc/ParaView-4.1.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.1 --- I guess I have some problem with OpenGL |
August 22, 2015, 18:03 |
Bruno Santos
Rep Power: 128 |
Without more details, the fix could be the one stated at the end of this file: https://github.com/OpenFOAM/ThirdPar...ter/README.org
August 22, 2015, 19:22 |
anton
Rep Power: 11 |
Thank you, "Uncomment line 30" works! I had compiled paraView and PV4FoamReader.
paraFoam works too. |
how do i fix installation error of ansys 19.0 on ubuntu 18.04 | rid_taki | ANSYS | 15 | June 7, 2021 06:32 |
[foam-extend.org] A smooth installation of foam-3.0-extend on OpenSUSE 13.1 64-bits | cookcaptain | OpenFOAM Installation | 7 | May 26, 2015 11:22 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 13:29 |
