[foam-extend.org] foam-extend-3.1 installation on cluster using system mpi and intel compiler
Old   August 12, 2015, 03:30
Default foam-extend-3.1 installation on cluster using system mpi and intel compiler
Manjura Maula Md. Nayamatullah
mmmn036 is on a distinguished road
I would like to install foam-extend-3.1 on a cluster using the system mpi and intel compiler in the system.
I made the following change in etc/baschrc:
1. foamCompiler : System
2. WM_COMPILER: Icc
3. WM_MPLIB: SYSTEMMPI
I made the following change in etc/setting.sh:
SYSTEMMPI)
export FOAM_MPI=mpi
export MPI_ARCH_PATH=/opt/apps/intel14/mvapich2/2.0b/
I also made change the wmake/rules/Linux64Icc/c according to https://github.com/OpenFOAM/OpenFOAM...s/linux64Icc/c
I am still seeing the following error:
+ WM_OPTIONS=linux64IccDPOptSYSTEMMPI
+ wmake libso mpi
linux64IccDPOptSYSTEMMPI/options:1: /work/02813/jzb292/foam/foam-extend-3.1/wmake/rules/linux64Icc/mplibSYSTEMMPI: No such file or directory
make: *** No rule to make target `/work/02813/jzb292/foam/foam-extend-3.1/wmake/rules/linux64Icc/mplibSYSTEMMPI'. Stop.
wmake error: file 'Make/linux64IccDPOptSYSTEMMPI/objectFiles' could not be created
Any help will be greatly appreciated.
mmmn036 is offline   Reply With Quote
Old   August 14, 2015, 13:21
I solved my issues.
Old   February 11, 2019, 11:35
Torsten Schenkel
tschenkel is on a distinguished road
Could you say how?
tschenkel is offline   Reply With Quote
Old   February 12, 2019, 11:26
Fatih Ertinaz
fertinaz is on a distinguished road
His messages are 3 years old, so I'm not sure if you can get a reply but what was missing at that time:
When one changes the settings to
${WM_MPLIB:=SYSTEMMPI}
then OF needs to have access to a file called "mplibSYSTEMMPI" under the "wmake/rules/linux64....." that provides linking options to the compiler.
Now, for someone who uses Intel MPI, it is not necessary to define "WM_MPLIB" as SYSTEMMPI even though technically it is true. But it is not needed simply because there is already a file called "mplibINTELMPI" with the correct content (of course you need point to the MPI_ARCH_PATH using sth. like I_MPI_ROOT). Alternatively, you can copy mplibINTELMPI as mplibSYSTEMMPI which will probably work fine but look a bit sloppy imho.
fertinaz is offline   Reply With Quote
[OpenFOAM.org] Install OpenFOAM 2.3.1 on cluster with Intel Compiler syavash OpenFOAM Installation 8 September 4, 2018 10:08
[OpenFOAM.org] oofem3.0.0 compilation errors with intel mpi compiler (boost 1.59.0) puneet336 OpenFOAM Installation 7 November 24, 2015 16:23
Cluster Windows 7 with Intel MPI brunofichos ANSYS 0 July 17, 2014 17:19
ERROR in installation with INTEL compiler milind543 SU2 Installation 2 September 29, 2013 11:46
installation with Intel MPI and Intel compilers achim OpenFOAM Installation 12 November 10, 2011 06:56
