[foam-extend.org] Ubuntu 14.04, Foam-extend 3.1: "command not found"
Old   August 6, 2015, 04:19
Unhappy Ubuntu 14.04, Foam-extend 3.1: "command not found"
LOU Lida
KangX1 is on a distinguished road
Dear foamers,
I try to install the foam-extend-3.1 on ubuntu 14.04 besides of231.
After compiling the foam extend with "Allwmake.firstInstall", I'm trying to run some test case. However, it always shows like "blockMesh: command not found".
So, what's the problem?
Thanks,
KangX1
KangX1 is offline   Reply With Quote
Old   August 8, 2015, 01:21
LOU Lida
can anyone help...?
Old   August 8, 2015, 06:53
anonymous
ssss is on a distinguished road
Did you include the alias for foamextend in your .bashrc file?
ssss is offline   Reply With Quote
Old   August 10, 2015, 06:25
LOU Lida
yes, I just follow tthe instruction of the foam extend installation guide. And source the bashrc in /etc. However, not any command can be found.
Old   August 10, 2015, 15:58
Retired Super Moderator
Bruno Santos
Greetings to all!
@KangX1: Then something very wrong happened while building foam-extend 3.1.
Please do the following steps, for diagnosing the problem:
  1. Start a new terminal.
  2. Run this command:
    echo $WM_PROJECT_DIR
    • If the command gave you nothing, then it's what we want.
    • If the command gave you something, then it probably will lead to confusion between the two versions. You will need to edit the file "~/.bashrc" and comment out any explicit lines that refer to OpenFOAM or foam-extend and that start with "source" or ".".
  3. If the command gave you nothing, now run:
    fe31
    Then run the previous command again:
    It should tell you the path to where foam-extend 3.1 is located.
  4. If everything is going well so far, run:
    foam
    ./Allwmake.firstInstall > log.make 2>&1
  5. Now run:
    which blockMesh
    • If it gives nothing or tells you that it can't find the file, then run:
      gzip < log.make > log.make.gz
      And attach the file "log.make.gz" to your next post.
    • If it tells you where blockMesh is located, then it's all OK.
As soon as we can see the contents of the file "log.make", it's possible to diagnose the problem.
Best regards,
Bruno
Old   August 10, 2015, 16:12
LOU Lida
I've tried the method above. Here's the log file.
Many Thanks,
Old   August 10, 2015, 17:15
Bruno Santos
Thanks, that makes it a lot easier to diagnose!
OK, first problem is that rpm is not installed. Did you install the suggested packages, as listed here: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04 - namely as explained in section "2.3 Ubuntu 14.04"?
The other errors are mostly related to the missing rpm installation, but the error related to blockMesh is because the package "libiberty-dev" is also not installed on your system.
Therefore, all indicates that the problem is that the necessary packages for building foam-extend are not yet installed in your system, as instructed in http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04
Old   August 10, 2015, 23:27
LOU Lida
It works!!!!!!!
Thannnnnnnks!!!
Old   September 22, 2015, 15:24
Wojciech Gołąbek
Woj3x is on a distinguished road
I have a similar problem as KangX1 so I tryed to use your solution but when I tryed to run Allwmake.firstInstall the terminal begins to run script but but it takes more than 2 hours and still I can only see is this:
I suppose that It shouldn't be the problem but I got also openfoam 2.4.
I include the alias for both programs like this:
So I totally do not know what's happening
Thank you in advance for your help
Woj3x is offline   Reply With Quote
Old   September 22, 2015, 15:28
LOU Lida
Dear Woj3x,
Have installed the "rpm" package before you compile for the first time?
As @wyldckat said, missing that part will cause that problem as I did.
Thanks.
Lida
Old   September 22, 2015, 15:51
Wojciech Gołąbek
Yes I did and when I tryed to use it again I received the following massage:
Reading package lists ... Done
Building dependency tree
Reading state information ... Done
Bison is already the newest version.
build-essential is already the newest version.
cmake is already the newest version.
flex is already the newest version.
libiberty-dev is already the newest version.
libncurses5-dev is already the newest version.
libXt-dev is already the newest version.
zlib1g-dev is already the newest version.
binutils-dev is already the newest version.
git-core is already the newest version.
graphviz is already the newest version.
libqt4-dev is already the newest version.
qt4-dev-tools is already the newest version.
rpm is already the newest version.
Mercurial is already the newest version.
The following packages were automatically installed and are no longer required:
linux-headers-3.19.0-25 linux-headers-3.19.0-25-generic
linux-image-3.19.0-25-generic linux-image-extra-3.19.0-25-generic
To remove them, use the "apt-get autoremove".
So I suppose that I did it correct
Best regards,
W. Gołąbek
Old   September 22, 2015, 15:54
LOU Lida
Best regards,
W. Gołąbek
It seems rpm package is not the one. Maybe u can try compile it again with the log, and upload the log so that everyone can help u to find out where it goes wrong.
BR,
Lida
Old   September 22, 2015, 16:03
Wojciech Gołąbek
But problem is that I can't use this script:
foam
and I suppose that I need to use it to get this log (I am not sure becouse I am new in linux)
how long did it take in your case to run it? As I wrote before in my case after 2 hours script still has not executed.
Best regards,
W. Gołąbek
Old   September 22, 2015, 16:08
LOU Lida
only input this
"./Allwmake.firstInstall > log.make 2>&1"
in the terminal
In my case, my laptop used 3 hours or more to run it. It's normal to use hours to do it.
Take it easy and get some coffee : )
Lida
Old   September 23, 2015, 08:38
Wojciech Gołąbek
Ok I found way to solve my problem.
First of all I leaved my PC for all night and I supposed that it definitely should be done after this time but I was wrong. Terminal still perform something in the background (I mean I didn't see any action in terminal window) .
I decided to check foam-extend folder and I saw new file log.make when I opend it I saw question from script file 'Proceed without compiling ParaView [Y/n]' so I wrote Y in terminal and after less than an hour the script was finally executed.
I hope this will help sb with same problem. Thank you for your help KangX1
Best regards,
W. Gołąbek
Old   September 23, 2015, 11:34
LOU Lida
You are welcome.
Old   October 21, 2015, 23:31
Default command not found
  #17
heidi
wendy987 is on a distinguished road
Dear fomers
I also try to install the foam-extend-3.1 on ubuntu 14.04 besides of240. I add
alias of240=’source $HOME/OpenFOAM/OpenFOAM-2.4.0/ect/bashrc’
alias fe31=’source $HOME/foam/foam-extend-3.1/ect/bashrc’
in $HOME/.bashrc
When I startup a new terminal, run of240, it success!
But when I startup a new terminal, run fe31, it show “command not found”.
Then I run env, the WM_PROJECT_DIR=/home/zhhy/foam/foam-extend-3.1
I don’t know why?
Who can help me, thank you!!
wendy987 is offline   Reply With Quote
Old   October 22, 2015, 17:14
Bruno Santos
Quick answer:
If looks like you manually wrote these lines here, because the correct lines are as follows:
alias of240='source $HOME/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc'
alias fe31='source $HOME/foam/foam-extend-3.1/etc/bashrc'
Notice the 2 very small details:
  1. The correct quote character is ' and not
  2. The folder is named "etc", not "ect"
In addition, try running these commands:
ls $HOME/foam/foam-extend-3.1/etc/bashrc
Does any of the two give you error messages?
Old   October 24, 2015, 22:31
heidi
Originally Posted by wyldckat View Post
Quick answer:
This shows:
zhhy@zhhy:~$ ls $HOME/foam/foam-extend-3.1/etc/bashrc
/home/zhhy/foam/foam-extend-3.1/etc/bashrc
zhhy@zhhy:~$ source $HOME/foam/foam-extend-3.1/etc/bashrc
bash: /home/zhhy/foam/foam-extend-3.1/bin/foamGetSystemInfo: Permission Denied
bash: /home/zhhy/foam/foam-extend-3.1/bin/foamCleanPath:
Permission Denied
bash: /home/zhhy/foam/foam-extend-3.1/bin/foamCleanPath: Permission Denied
zhhy@zhhy:~$ sudo source $HOME/foam/foam-extend-3.1/etc/bashrc
[sudo] password for zhhy:
sudo:source: command not found
what can i do next?
Old   October 25, 2015, 09:01
Bruno Santos
Quick questions:
  1. What where the exact steps you took for downloading and unpacking foam-extend 3.1?
    • Or in other words, what steps did you take for getting the files into the folder "/home/zhhy/foam/foam-extend-3.1/"?
  2. What does this command give you?
    ls -l /home/zhhy/foam/foam-extend-3.1/bin/foamCleanPath
foam extend 3.1
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
