[foam-extend.org] Ubuntu 14.04, Foam-extend 3.1: "command not found"
Old   October 26, 2015, 21:23
heidi
wendy987 is on a distinguished road
Originally Posted by wyldckat View Post
Quick questions:
  1. What where the exact steps you took for downloading and unpacking foam-extend 3.1?
    • Or in other words, what steps did you take for getting the files into the folder "/home/zhhy/foam/foam-extend-3.1/"?
  2. What does this command give you?
    ls -l /home/zhhy/foam/foam-extend-3.1/bin/foamCleanPath
Hi wyldckat:
Thank you very much. I download a snapshot (.tgz) of the source code from:
http://sourceforge.net/projects/open...am-extend-3.1/
then unpack.
I git clone git://git.code.sf.net/p/openfoam-extend/foam-extend-3.1, then the foam-exted-3.1 can be compiled successfully! I don't why?
but the new problem come, when i run the tutorial, blockMesh, the error show: command not found. When i install the OpenFOAM2.4.0, the paraview has been installed. the paraview need reinstall? what can i do next? Thank you very much!!
wendy987 is offline   Reply With Quote
Old   October 31, 2015, 08:18
Retired Super Moderator
Bruno Santos
Quick answer: Please follow the instructions I wrote in post #5: http://www.cfd-online.com/Forums/ope...tml#post558995 - post #5, then continue reading the posts for more details.
Old   July 5, 2016, 06:42
Viraj Belekar
viraj20feb is on a distinguished road
Hello Mr. Bruno,
My system is unable to find the icoLagrangianFoam command. I have attached the log.make.gz file with this post. Can you please help? Thank you
viraj20feb is offline   Reply With Quote
Old   July 5, 2016, 06:49
LOU Lida
KangX1 is on a distinguished road
Hi, Viraj
I think the problem is that the icoLagrangianFoam is not included in this version.
Lida
KangX1 is offline   Reply With Quote
Old   July 5, 2016, 06:52
Viraj Belekar
Hi Lida,
I am trying to install the latest version foam-extend-3.1 (https://openfoamwiki.net/index.php/I...om_source_code). And I am quite sure that icoLagrangianFoam is there in this version. Can you please help?
Old   July 5, 2016, 06:57
LOU Lida
Hi, Viraj
I've checked the source of the foam-extend-31. It seems that the source code of icoLagrangianFoam is not in there.
So, my advice is that you may find the source of the icoLagrangianFoam in other version of foam and compile it manually. The tutorial of compiling a new solver is as follows: http://cfd.direct/openfoam/user-guid...-applications/
Lida
Old   July 7, 2016, 08:01
Default wmake command
  #27
Viraj Belekar
Hi Lida,
So as you said I would have to compile in order to use icoLagrangianFoam solver. In foam extend 3.1, the solver is already coded(please see attached). I just need to give the 'wmake' command after entering the case directory, am I right?
Old   July 7, 2016, 08:04
LOU Lida
Hi, Viraj
You are right, just use the 'wmake' command.
Lida
Old   September 26, 2016, 07:09
Viraj Belekar
I am facing the same compiling problem {blockMesh: command not found}. I have attached my log file with this post. Pleas help
Old   September 26, 2016, 19:02
Bruno Santos
Quick answer @viraj20feb: Please run the following commands:
cd ~/foam/foam-extend-3.1
find src applications -name "*.L" -type f | xargs sed -i -e 's=\(YY\_FLEX\_SUBMINOR\_VERSION\)=YY_FLEX_MINOR_VERSION < 6 \&\& \1='
./Allwmake > log.make 2>&1
This was already explained at the end of the page here: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04
Last edited by wyldckat; September 27, 2016 at 17:29. Reason: changed version from 3.2 to 3.1 in the first command... I had copy-pasted without changing :(
Old   September 27, 2016, 01:51
Viraj Belekar
cd ~/foam/foam-extend-3.2
Hi wyldckat,
I was able to install foam-extend-3.2.
Many thanks
Old   September 27, 2016, 17:30
Bruno Santos
Originally Posted by viraj20feb View Post
Hi wyldckat,
Many thanks
Sorry, I had made a mistake in the version number for the first command. I've updated my previous post, in case you still need foam-extend 3.1.
foam extend 3.1
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
