[OpenFOAM.org] Problems with Paraview (OpenFOAM 2.4.0 from source code in Ubuntu 14.04)
Old   July 26, 2015, 08:24
Default Problems with Paraview (OpenFOAM 2.4.0 from source code in Ubuntu 14.04)
Gerrit is on a distinguished road
I am new to OpenFoam CFD and hope to not ask a stupid question or repeat an answered question.
I have Ubuntu 14.04 LTS on my computer and followed the guide from this page:http://www.openfoam.org/download/source.php
After finishing the installation I followed the steps on that page of "Getting Started".
cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
blockMesh
icoFoam
this part ran without trouble. In the folder I have now new folders of the calculation steps from 0 to 0.5.
When using the command
paraFoam
, I receive an error massage:
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
./Allwclean
./Allwmake
Following that instructions I receive a new error massage at
 ./Allwmake
ERROR: ParaView not found in /home/gerrit/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc/ParaView-4.1.0
I checked the folder linux64Gcc and there is no Paraview folder.
What would be the next step? Download Paraview somewhere and simply copy it in that folder?
Thanky you very much.
Best regards
Gerrit
Gerrit is offline   Reply With Quote
Old   July 26, 2015, 10:38
Retired Super Moderator
Bruno Santos
Greetings Gerrit and welcome to the forum!
According to your description, it seems that perhaps you didn't follow the steps from the section "Compiling Paraview and the Paraview Reader Module" on that page, where it instructs how to build ParaView 4.1.0 from source code: http://www.openfoam.org/download/source.php
The source code itself is already provided in the folder "ThirdParty-2.4.0", therefore you don't need to download ParaView's source code.
If you have trouble following the instructions provided on that page, you might want to try these instructions: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04
Best regards,
Bruno
Old   July 26, 2015, 14:00
Hi Bruno,
thank you for your answer, I will try it again!
Best regards
Gerrit
Old   August 5, 2015, 17:14
I could get it to run by following the Ubuntu Deb Pack Installation.
http://www.openfoam.org/download/ubuntu.php
Thank you anyway!
BR
Gerrit
Old   August 15, 2015, 12:05
Davi Barreira
davibarreira is on a distinguished road
Gerrit,
I recently faced the same problem with OF 2.4.x. I solved using the solution provided here http://www.openfoam.org/mantisbt/view.php?id=1734.
Basically, go into the folder OpenFOAM/ThirdParty-2.4.x/ParaView-4.1.0/VTK/Rendering/OpenGL , and alter the vtkXOpenGLRenderWindow.cxx file, by uncommenting #define GLX_GLXEXT_LEGACY
davibarreira is offline   Reply With Quote
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
