[OpenFOAM.org] Installing OpenFOAM 2.4.0 on CentOS 6.6 |
July 22, 2015, 07:40 |
Well, that explains it all, even the guys at SF encounter nasty bugs!.
Thanks, I've been following your 2.3.1 guide with smalls modifications because the 2.4.0 one wasn't out yet. Are the changes in step 17 critical (CentOS 6.6)? Sorry if this is off-topic, but there's no discussion thread up yet, feel free to move or delete the post if needed. |
July 25, 2015, 09:54 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Kyrox,
I've moved your post from the other thread http://www.cfd-online.com/Forums/ope...oam-2-3-x.html - so that we can now have a thread for discussing how to install OpenFOAM 2.4.0 on CentOS 6.6. As for your question: Step #17 (fixing and installing ParaView 4.1.0) changed a bit between 2.3.1 and 2.4.0, because the file "etc/tools/ParaView4Functions" is already fixed. The other remaining fix relates to being able to build ParaView with both the MPI and Python options. Best regards, Bruno
February 7, 2016, 04:53 |
Installing OpenFoam 2.4 on CentOS 6.7
belamou
Rep Power: 17 |
I am new to OF... i am trying to install OF on CentOs 6.7 i686 , i used the procedure on wiki for OF 2.4 on CentOs 6.6. I think that OF is installed correctly (hope so !), however Paraview (ParaFoam) is not installed , when running it i have this error message: Code:
$ paraFoam FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean Code:
[ 16%] Building CXX object VTK/Rendering/OpenGL/CMakeFiles/vtkRenderingOpenGL.dir/vtkXOpenGLRenderWindow.cxx.o In file included from /usr/include/GL/glx.h:333, from /home/Donminoti/OpenFOAM/ThirdParty-2.4.0/ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx:31: /usr/include/GL/glxext.h:480: error: GLintptr has not been declared /usr/include/GL/glxext.h:480: error: GLintptr has not been declared /usr/include/GL/glxext.h:480: error: GLsizeiptr has not been declared /usr/include/GL/glxext.h:481: error: GLintptr has not been declared /usr/include/GL/glxext.h:481: error: GLintptr has not been declared /usr/include/GL/glxext.h:481: error: GLsizeiptr has not been declared make[2]: *** [VTK/Rendering/OpenGL/CMakeFiles/vtkRenderingOpenGL.dir/vtkXOpenGLRenderWindow.cxx.o] Error 1 make[1]: *** [VTK/Rendering/OpenGL/CMakeFiles/vtkRenderingOpenGL.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-4.1.0 Set environment variables: export ParaView_DIR=/home/Donminoti/OpenFOAM/ThirdParty-2.4.0/platforms/linuxGcc48/ParaView-4.1.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.1 --- Done Thanks Last edited by wyldckat; February 7, 2016 at 12:19. Reason: Added [CODE][/CODE] markers |
February 7, 2016, 12:26 |
Bruno Santos
Rep Power: 128 |
Quick answer @donminoti: I see that you've followed these instructions: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.6 - I'm just adding this link-back, because I forgot to mention it in an earlier post.
This is odd, very odd. Please try the following commands: Code:
cd $WM_THIRD_PARTY_DIR sed -i -e 's=//#define GLX_GLXEXT_LEGACY=#define GLX_GLXEXT_LEGACY=' \ ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx edit: Hopefully this will fix the problem. I find this odd, because I didn't need this fix when I tested with CentOS 6.6. I'll have to try it out with 6.7. Last edited by wyldckat; February 7, 2016 at 12:27. Reason: see "edit:" |
February 7, 2016, 15:23 |
belamou
Rep Power: 17 |
Thank you for the replay... i have try what you've suggested .... on the log.makePV it seems to go untill the end ( 100%) but still with error :
######### . . [100%] Built target vtkParaViewDocumentation Linking CXX executable ../../bin/paraview /home/Donminoti/OpenFOAM/ThirdParty-2.4.0/platforms/linuxGcc48/qt-4.8.6/lib/libQtCLucene.so.4: undefined reference to `std::__detail::_List_node_base::_M_unhook()@GLIBC XX_3.4.15' /home/Donminoti/OpenFOAM/ThirdParty-2.4.0/platforms/linuxGcc48/qt-4.8.6/lib/libQtCLucene.so.4: undefined reference to `std::__detail::_List_node_base::_M_hook(std::__de tail::_List_node_base*)@GLIBCXX_3.4.15' collect2: ld returned 1 exit status make[2]: *** [bin/paraview] Error 1 make[1]: *** [Applications/ParaView/CMakeFiles/paraview.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-4.1.0 Set environment variables: export ParaView_DIR=/home/Donminoti/OpenFOAM/ThirdParty-2.4.0/platforms/linuxGcc48/ParaView-4.1.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.1 --- Done ##################### When builling Paraview i have this error message [....PV4Readers]$ ./Allwmake ERROR: ParaView not found in /home/donminoti/OpenFOAM/ThirdParty-2.4.0/platforms/linuxGcc48/ParaView-4.1.0 |
February 7, 2016, 15:31 |
Bruno Santos
Rep Power: 128 |
Quick answer: Those are signs of using the wrong GCC version, possibly due to something having gone wrong when you initialized the OpenFOAM environment. Please to the following commands and please tell me what they give you:
grep of240 $HOME/.bashrc which gcc which g++ gcc --version g++ --version |
February 7, 2016, 17:10 |
belamou
Rep Power: 17 |
Thank you for the reply, the output are bellow... actually it shows GCC 4.4.7 !!!!, then GCC 4.8 was not installed !!!
grep of240 $HOME/.bashrc alias of240='module load openmpi-i386; source $HOME/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc WM_NCOMPPROCS=2 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI WM_ARCH_OPTION=32' which gcc /usr/bin/gcc which g++ /usr/bin/g++ gcc --version gcc (GCC) 4.4.7 20120313 (Red Hat 4.4.7-16) Copyright (C) 2010 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. g++ --version g++ (GCC) 4.4.7 20120313 (Red Hat 4.4.7-16) Copyright (C) 2010 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. |
February 7, 2016, 17:32 |
Bruno Santos
Rep Power: 128 |
Quick answer: OK, not to worry for now. We should have the log file "mkgcc.log" that tells us what happened when building GCC 4.8. Please run the following command:
foam3rdParty tail -n 20 mkgcc.log It's a fairly long log file, so compressing it might still result in a very large file, but you can still try it: Code:
gzip < mkgcc.log > mkgcc.log.gz |
February 7, 2016, 17:40 |
#9 |
belamou
Rep Power: 17 |
thanks again for your help.
i went to ThirdParty-2.4.0 folder , and ran the command :tail -n 20 mkgcc.log. bellow is the output in a given directory, LIBDIR, you must either use libtool, and specify the full pathname of the library, or use the `-LLIBDIR' flag during linking and do at least one of the following: - add LIBDIR to the `LD_LIBRARY_PATH' environment variable during execution - add LIBDIR to the `LD_RUN_PATH' environment variable during linking - use the `-Wl,-rpath -Wl,LIBDIR' linker flag - have your system administrator add LIBDIR to `/etc/ld.so.conf' See any operating system documentation about shared libraries for more information, such as the ld(1) and ld.so(8) manual pages. ---------------------------------------------------------------------- make[4]: Nothing to be done for `install-data-am'. make[4]: Leaving directory `/home/donminoti/OpenFOAM/ThirdParty-2.4.0/build/linux/gcc-4.8.4/i686-pc-linux-gnu/libatomic' make[3]: Leaving directory `/home/donminoti/OpenFOAM/ThirdParty-2.4.0/build/linux/gcc-4.8.4/i686-pc-linux-gnu/libatomic' make[2]: Leaving directory `/home/donminoti/OpenFOAM/ThirdParty-2.4.0/build/linux/gcc-4.8.4/i686-pc-linux-gnu/libatomic' make[1]: Leaving directory `/home/donminoti/OpenFOAM/ThirdParty-2.4.0/build/linux/gcc-4.8.4' + echo 'Built: gcc-4.8.4' Built: gcc-4.8.4 |
February 7, 2016, 18:19 |
#10 |
Bruno Santos
Rep Power: 128 |
Mmm... so all signs point to GCC having been built without problems. Then there is likely a glitch in the "settings.sh" file.
OK, I need two things:
February 7, 2016, 18:35 |
#11 |
belamou
Rep Power: 17 |
it gives
gcc_version=gcc-4.8.4 seems to be good the file is in attachment Thanks |
February 7, 2016, 19:14 |
#12 |
Bruno Santos
Rep Power: 128 |
This is really strange... what do the following commands give you?
foam3rdParty ls -l platforms/linux/gcc-4.8.4/ ls -l platforms/linux/gcc-4.8.4/bin |
February 8, 2016, 16:21 |
#13 |
belamou
Rep Power: 17 |
sorry, ls -l platforms/linux/gcc-4.8.4/ total 24 drwxrwxr-x. 2 donminoti donminoti 4096 Feb 6 08:18 bin drwxrwxr-x. 4 donminoti donminoti 4096 Feb 6 08:18 i686-pc-linux-gnu drwxrwxr-x. 3 donminoti donminoti4096 Feb 6 08:17 include drwxrwxr-x. 3 donminoti donminoti 4096 Feb 6 08:18 lib drwxrwxr-x. 3 donminoti donminoti 4096 Feb 5 23:40 libexec drwxrwxr-x. 6 donminoti donminoti 4096 Feb 5 23:41 share ls -l platforms/linux/gcc-4.8.4/bin total 78080 -rwxr-xr-x. 1 donminoti donminoti 3483448 Feb 6 08:18 addr2line -rwxr-xr-x. 2 donminoti donminoti 3623703 Feb 6 08:18 ar -rwxr-xr-x. 2 donminoti donminoti 5086489 Feb 6 08:18 as -rwxr-xr-x. 4 donminoti donminoti 2539012 Feb 5 23:40 c++ -rwxr-xr-x. 1 donminoti donminoti 3442690 Feb 6 08:18 c++filt -rwxr-xr-x. 1 donminoti donminoti 2533626 Feb 5 23:41 cpp -rwxr-xr-x. 1 donminoti donminoti 78000 Feb 6 08:18 elfedit -rwxr-xr-x. 4 donminoti donminoti 2539012 Feb 5 23:40 g++ -rwxr-xr-x. 3 donminoti donminoti 2531166 Feb 5 23:41 gcc -rwxr-xr-x. 2 donminoti donminoti 109142 Feb 5 23:41 gcc-ar -rwxr-xr-x. 2 donminoti donminoti 109102 Feb 5 23:41 gcc-nm -rwxr-xr-x. 2 donminoti donminoti 109114 Feb 5 23:41 gcc-ranlib -rwxr-xr-x. 1 donminoti donminoti 1323184 Feb 5 23:41 gcov -rwxr-xr-x. 1 donminoti donminoti 3933616 Feb 6 08:18 gprof -rwxr-xr-x. 4 donminoti donminoti 2539012 Feb 5 23:40 i686-pc-linux-gnu-c++ -rwxr-xr-x. 4 donminoti donminoti 2539012 Feb 5 23:40 i686-pc-linux-gnu-g++ -rwxr-xr-x. 3 donminoti donminoti 2531166 Feb 5 23:41 i686-pc-linux-gnu-gcc -rwxr-xr-x. 3 donminoti donminoti 2531166 Feb 5 23:41 i686-pc-linux-gnu-gcc-4.8.4 -rwxr-xr-x. 2 donminoti donminoti 109142 Feb 5 23:41 i686-pc-linux-gnu-gcc-ar -rwxr-xr-x. 2 donminoti donminoti 109102 Feb 5 23:41 i686-pc-linux-gnu-gcc-nm -rwxr-xr-x. 2 donminoti donminoti 109114 Feb 5 23:41 i686-pc-linux-gnu-gcc-ranlib -rwxr-xr-x. 4 donminoti donminoti 4827499 Feb 6 08:18 ld -rwxr-xr-x. 4 donminoti donminoti 4827499 Feb 6 08:18 ld.bfd -rwxr-xr-x. 2 donminoti donminoti 3509636 Feb 6 08:18 nm -rwxr-xr-x. 2 donminoti donminoti 4218294 Feb 6 08:18 objcopy -rwxr-xr-x. 2 donminoti donminoti 4934220 Feb 6 08:18 objdump -rwxr-xr-x. 2 donminoti donminoti 3623698 Feb 6 08:18 ranlib -rwxr-xr-x. 1 donminoti donminoti 896173 Feb 6 08:18 readelf -rwxr-xr-x. 1 donminoti donminoti 3473656 Feb 6 08:18 size -rwxr-xr-x. 1 donminoti donminoti 3471884 Feb 6 08:18 strings -rwxr-xr-x. 2 donminoti donminoti 4218289 Feb 6 08:18 strip |
February 8, 2016, 17:28 |
#14 |
belamou
Rep Power: 17 |
I will try to make another clean installation and let you know. ..
Thank you for your help |
February 13, 2016, 14:19 |
#15 |
belamou
Rep Power: 17 |
Hi wyldckat,
to give a feedback.... I have re-installed the CentOs and OpenFoam 2.4, this time CentOs 6.5 ( last time it was 6.7) ... but still the same problem with paraview ( paraFoam). again i was obliged to add (the commande below) , before step 17 / 2.....! #########" cd $WM_THIRD_PARTY_DIR sed -i -e 's=//#define GLX_GLXEXT_LEGACY=#define GLX_GLXEXT_LEGACY=' \ ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx #########"" the paraFoam command , gives: ##########" FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake ######### the last lines of log.makePv , are: ########## 100%] Built target vtkParaViewDocumentation Linking CXX executable ../../bin/paraview /home/donminoti/OpenFOAM/ThirdParty-2.4.0/platforms/linuxGcc48/qt-4.8.6/lib/libQtCLucene.so.4: undefined reference to `std::__detail::_List_node_base::_M_unhook()@GLIBC XX_3.4.15' /home/donminoti/OpenFOAM/ThirdParty-2.4.0/platforms/linuxGcc48/qt-4.8.6/lib/libQtCLucene.so.4: undefined reference to `std::__detail::_List_node_base::_M_hook(std::__de tail::_List_node_base*)@GLIBCXX_3.4.15' collect2: ld returned 1 exit status make[2]: *** [bin/paraview] Error 1 make[1]: *** [Applications/ParaView/CMakeFiles/paraview.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-4.1.0 Set environment variables: export ParaView_DIR=/home/donminoti/OpenFOAM/ThirdParty-2.4.0/platforms/linuxGcc48/ParaView-4.1.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.1 ######### Something is wrong with the OpenFoam 2.4 and CentOs 6.x... Thanks |
February 14, 2016, 16:36 |
#16 |
Bruno Santos
Rep Power: 128 |
Hi donminoti,
This is reminding me of a problem that happened some months ago with another forum member. There was an important detail he didn't mention or that I didn't notice earlier. Let me see if I can find it... OK, the first thread I found was this one: http://www.cfd-online.com/Forums/ope...tos-6-5-a.html - please check if you are doing anything similar to the descriptions given by the forum member kpsl. Then there is this thread: http://www.cfd-online.com/Forums/ope...u-12-04-a.html And finally, there is also this post: http://www.cfd-online.com/Forums/ope...tml#post369975 - post #12 Please let me know if there is any specific personal configuration that you do in your CentOS installations. For example, if you use any customized ".bash*" scripts that contain aliases or environment variables that might be interfering with the installation. Best regards, Bruno
February 29, 2016, 22:18 |
#17 |
Bashar
Rep Power: 11 |
Hi
Sorry to bother you , but I was having the same issue, but I followed you directions in this post and I got the para-view . Unfortunately, when I tried to run it I get the following error message: Code:
[bashar@basharhpc ~]$ of240 [bashar@basharhpc ~]$ paraFoam WARN file does not exist: ./system/controlDict ./system/fvSchemes ./system/fvSolution created temporary 'bashar.OpenFOAM' --> FOAM FATAL IO ERROR: cannot find file file: /home/bashar/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Last edited by wyldckat; March 6, 2016 at 12:45. Reason: Added [CODE][/CODE] markers |
March 1, 2016, 08:24 |
#18 |
belamou
Rep Power: 17 |
Actually, i was unable to correctly install OF 2.4 on Centos 6.6, i am using Ubuntu for the moment. |
March 6, 2016, 12:48 |
#19 | ||
Bruno Santos
Rep Power: 128 |
Quick answer @Bashar1978:
Please follow the tutorials in the OpenFOAM User Guide more carefully. If you don't know where to find the OpenFOAM User Guide, I'll quote myself: Quote:
May 13, 2016, 05:57 |
same problem as donminoti
#20 |
Johannes
Rep Power: 15 |
Hello!
I have the same problem as donminoti. Is there still no solution for the issue with ParaView-4.1.0 installation on (CentOS6.6)/CentOS6.7?? kr, Johannes Last edited by jfw_cfd; May 30, 2016 at 08:14. |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
[OpenFOAM.org] Problems installing OpenFOAM 2.4.0 on Ubuntu 16.04 | donminoti | OpenFOAM Installation | 13 | January 13, 2021 18:07 |
[swak4Foam] Error: Installing swak4Foam into OpenFOAM 2.3.0 on CentOS 7 | mushtime | OpenFOAM Community Contributions | 9 | July 23, 2017 16:27 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
OpenFOAM Foundation releases OpenFOAMŪ 2.4.0 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 0 | May 22, 2015 11:41 |
