[OpenFOAM.org] OpenFoam 2.1.1 not completely works in Debian jessie
Old   July 9, 2015, 01:26
Default OpenFoam 2.1.1 not completely works in Debian jessie
David Long
keepfit is on a distinguished road
Dear Foamers,
for some reason, I wont update my OpenFoam 2.1.1 to the latest version. However, I upgraded my system from Debian 7.0 to 8.0., i.e. the compile environment upgraded.
I experienced some problems:
1) ./Allwmake in the src folder, all passed. However, to compile all "applications", especially some solvers in combustion, the libbasicThermophysicalModels.so seems compiled not correctly or something, although I did "wmake libso" for it several times.
2) Some common solvers such as interFoam seem working. But they wont work in parallel run.
$ mpirun -np 2 interFoam -parallel
It looks like opal_init failed for some reason; your parallel process is
likely to abort.  There are many reasons that a parallel process can
fail during opal_init; some of which are due to configuration or
environment problems.  This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
  opal_shmem_base_select failed
  --> Returned value -1 instead of OPAL_SUCCESS
[FLY:19226] [[INVALID],INVALID] ORTE_ERROR_LOG: Error in file runtime/orte_init.c at line 79
[FLY:19226] [[INVALID],INVALID] ORTE_ERROR_LOG: Error in file orterun.c at line 694
Debian Jessie:
Cmake version: 3.0.2
GCC:4.9
OpenMPI: 1.5.3 or system installed 1.6.5
Thanks in advance
keepfit is offline   Reply With Quote
Old   July 18, 2015, 18:46
Retired Super Moderator
Bruno Santos
Greetings David,
Are you doing a clean build? Or did you copy the OpenFOAM 2.1.1 version you had installed in your previous machine?
In other words, can you please provide more details on the steps you've taken?
Best regards,
Bruno
compilation error, openfoam 2.1.1, parallel error
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 05:43
Problem in recompiling a turbulence model in OpenFoam 2.1.1 pascool OpenFOAM Programming & Development 6 October 3, 2012 13:03
